Piston/Rod Order
Old Jan 14, 2008 | 01:49 PM
JScott3d's Avatar
Default Piston/Rod Order
Well I am rebuilding my LS block and I had the pistons sitting on my workbench when my wife came out and moved them so she could do some work. Now mind you I had just set them in order before numbering them and had to run to work. Well she moved them out of order. Will it be ok to put back together without being in the same cylinder they came out of? They are getting new rings and bearing and the block is getting honed.
Old Jan 15, 2008 | 06:11 PM
JScott3d's Avatar
Default Re: Piston/Rod Order (JScott3d)
Anyone?
cityofcaterpillars
Engine Machining & Assembly
Jul 19, 2016 05:10 AM
b16bri
Oct 11, 2010 05:39 PM
KingOfQB
10
Mar 4, 2006 07:30 AM
haggar
Aug 8, 2003 07:41 AM
