cut splice injectors. obd2-obd1
Old Jan 14, 2008 | 01:16 PM
IIXtremeHansen's Avatar
Default cut splice injectors. obd2-obd1
obd2 - obd1
its just basic color match right?
i had looked up on google and it said something about you have to reverse it but i think its some wrong info.
all injectors come with a pairing yellow wire with one diff. color.
are you suppose to color match or wire it vise versa?
Old Jan 14, 2008 | 01:49 PM
pdiggitydogg's Avatar
remove the blue box thingy in the obd2 injector plug and the obd1 injectors will fit fine
if you dont have injector plugs on the harness, yes youre just matching the 1 wire color
Old Jan 14, 2008 | 01:50 PM
Relic1's Avatar
^^^ there is that...
as far as colors.
OBD1 civic
cyl1-brown
cyl2-red
cyl3-light blue
cyl4-yellow
yellow/black common connection to 12V ignition power
OBD2 civic
cyl1-brown
cyl2-red
cyl3-blue
cyl4-yellow
OBD2 teg
cyl1-brown
cyl2-red
cyl3-blue
cyl4-yellow
Old Jan 14, 2008 | 03:27 PM
CivicSpoon's Avatar
Default Re: cut splice injectors. obd2-obd1 (Dickies_n_FlipFlops)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dickies_n_FlipFlops &raquo;</TD></TR><TR><TD CLASS="quote">obd2 - obd1
are you suppose to color match or wire it vise versa?</TD></TR></TABLE>
They are in fact reversed. If you look at both harnesses side by side; the Yellow/Black wires will be on opposite sides of the injector plugs. So you are still matching the colored wires together and matching the yel/blk wires together.
Old Jan 14, 2008 | 05:00 PM
great, thanks yall
turbodailydan
Aug 13, 2009 04:13 AM
xsellxoutx
Jul 12, 2009 04:44 PM
h22abuyer
May 5, 2006 12:27 PM
SupaFly_Honda
Jan 12, 2005 02:05 AM
G U E C O
Jan 30, 2004 06:59 PM
