Does anyone know how to install prothane motor mount inserts?
How flexible is the mount right now? It looks like you can clamp down on one side and then put the insert in on the other and then do the same for the other side. It looks like it should have the flex to do so. I'm just guessing on this one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by . a d a m »</TD></TR><TR><TD CLASS="quote">I have a 96 Civic DX and I can't seem to get the driver side mount in.
Looks like this.
The prothane kit a good kit much better then the ES kit just wanna get that out there
HOWEVER to answer your question you have push the two bushings around under the metal plate i hope that makes sense?
It is a bitch to do and in my opinion not worth the effort case and point blew mine very easily and then converted to the EG style mount they have for the drivers side you can get the kit quite cheap here on honda-tech well worth the money and the reassurance as for the trans and rear mount both work very well!
Richard…
Looks like this.
</TD></TR></TABLE>The prothane kit a good kit much better then the ES kit just wanna get that out there
Richard…
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JShull »</TD></TR><TR><TD CLASS="quote">How flexible is the mount right now? It looks like you can clamp down on one side and then put the insert in on the other and then do the same for the other side. It looks like it should have the flex to do so. I'm just guessing on this one.</TD></TR></TABLE>
Yeah, I was trying that and then my old man made a good point, once I get one side in it will be hard to clamp that side down in order to get the other side in. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Richard... »</TD></TR><TR><TD CLASS="quote">
Richard…
Do you think it would hurt if I just used the passenger side mount and the rear mount insert? I'm afraid that will put all the stress on the driver side mount and cause it to fail. I guess I'll wrestle with it tomorrow and try to get it in there.
Richard…
Do you think it would hurt if I just used the passenger side mount and the rear mount insert? I'm afraid that will put all the stress on the driver side mount and cause it to fail. I guess I'll wrestle with it tomorrow and try to get it in there. </TD></TR></TABLE>
im saying change the drivers side mount out for the innovative one or something like that
however if you do not wish too do that it will take a bit of doing but the insert will go around the top of that OEM mount just under the metal strip
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bejita »</TD></TR><TR><TD CLASS="quote">WTF is prothane?? Do you mean polyurathane? </TD></TR></TABLE>
It's another company like ES.
Yeah I know where it goes, it's just a huge bitch, I was wondering if theres a specific trick or if you just jimmy it in there.
Yeah I know where it goes, it's just a huge bitch, I was wondering if theres a specific trick or if you just jimmy it in there. </TD></TR></TABLE>
all you have to do is lube the hell out of it then i got a big paid of channel locks and squeezed that bitch in there and presto your done
way easier said then done however it is doable!
good luck!
good luck!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones »</TD></TR><TR><TD CLASS="quote">
It's another company like ES.</TD></TR></TABLE>
ES sucks there bushing suck prothane is far better Quality IMO!
Modified by Richard... at 3:46 PM 1/15/2008
From: So Cal where old pople try to race you, U.S.A
i didnt really want to read through the argument to see if your question got answered, but i used a big *** c-clamp and clamped one side pushed it in, and vice versa to the other side. worked for me and hopefully it'll work for you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaKINE-Ek »</TD></TR><TR><TD CLASS="quote">i didnt really want to read through the argument to see if your question got answered, but i used a big *** c-clamp and clamped one side pushed it in, and vice versa to the other side. worked for me and hopefully it'll work for you
Good call
I'm going to go out to the garage and get a c-clamp, I'll report back shortly.
</TD></TR></TABLE>Good call
Good call
I'm going to go out to the garage and get a c-clamp, I'll report back shortly. </TD></TR></TABLE>
It worked, thanks for the tip
Good call
dozer1313
Nov 3, 2004 06:24 PM
