car all of sudden won't start (searched)
yeah this is really random.
it was driving home fine yesterday and then when i tryed to go back out later none of the check engine light or brake light will come on and can't hear the fuel pump. checked all fuses and all of them are fine. has to be something with wiring.
-91 honda crx
-b18b swap
-p75 ecu with conversion harness
-battery relocation
-turbo'ed
anyone?! this sucks, i been trying to look at all the wiring for like an hour
-91 honda crx
-b18b swap
-battery relocation
-turbo'ed
you should have a code. check for it.
Edit:sorry read that wrong thought you said had cel check your grounds if you are sure that the battery is good
Modified by twiztid17thninja at 9:37 AM 1/15/2008
naw my battery is fine. all wired up tightened and everything. it has to be main relay or all the crazyness in my wiring harness.
if it comes down to it, id get a 12v current tester and run along the wires from the batt to the starter and find where im loosing power.. i know one of the wires on my selenoid(91 si hatch) likes to fall off now and again..
If you have no lights what so ever, something is wrong with your battery, main hot wire, or your main grounds.
I know you already checked them... but you should remove, clean and reinstall your battery cables.
well i already checked all my fuses in the engine bay too. i guess i'll try checking out the battery cables and main grounds, something could have came loose. mmm i might try picking up a main relay.
well i'll keep ya updated
90sedan
Jul 25, 2007 04:49 PM
