ECU Code 14 - Idler Control Valve Issue.
Old Jan 14, 2008 | 11:47 AM
kluminaliti's Avatar
Default ECU Code 14 - Idler Control Valve Issue.
to start let me tell you the history: 99 Honda Civic SI B16A2
About 7 weeks ago i swap the head of my car - while i was pulling the old head out i couldn't get to the manifold bottom bolts so I disconnected everythign attached to the intake manifold including the ICV and i pulled the head with the manifold. After swaping heads, i used my old Intake Manifold and re attached the ICV...
Since then my Check Engine Light comes on and my rpm fluctuates on 1500RPM. Have any clue what's going on?
Thanks
Old Jan 14, 2008 | 11:42 PM
mtber's Avatar
Default Re: ECU Code 14 - Idler Control Valve Issue. (kluminaliti)
Make sure that you have the proper 2 wire plug plugged into the idle air control valve
Old Jan 16, 2008 | 02:06 PM
Default Re: ECU Code 14 - Idler Control Valve Issue. (mtber)
i checked the 2 wires in the back and they are good...is there anything else i need to check?
Old Jan 28, 2008 | 03:44 PM
sashaval22's Avatar
try to unplug your iacv while the car is running and your idle should drop if it doesnt that means your iacv.
HAZARD_1310
10
Aug 14, 2007 11:58 PM
user 996328629
Jul 15, 2003 06:42 PM
b16racr91
Mar 2, 2003 09:29 PM
TypeR0207
13
May 29, 2002 06:12 AM
