TPS HELP
what is a correct way to set the TPS to make sure that its in the right position because i have tryed to adjust it and nothing changes but the idle when u try to move it forward.The check engine light want quit giving me the code 7 which is the TPS Sensor?? HELP
did a quick search for tps. second thread about this in the last week.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">You need to connect a multimeter to the tps and move the sensor around until the correct ohm specs are achieved.
With the TB closed, sensor disconnected, ign off:
Pins 1 and 2 = 0.5-0.9ohms
Pins 2 and 3 = 3.6-5.4ohms
You also need to be sure you have correct voltage, sensor connected, ign 'on':
Pins 1 and 3
0.5volts with the TB closed
4.5volts with the TB fully open
These specs should also be correct from the factory. If theyre not, and you havent replaced the tps, you know its time to do so.
If you have replaced the tps and these readings arent met, your sensor isnt positioned properly</TD></TR></TABLE>
hope this helps
Pins 1 and 3
hope this helps
Jakester9500
Nov 19, 2008 07:10 AM
hondaeg8
May 14, 2004 10:23 AM
