how to make an obd-1 b16 work...
Old Jun 30, 2002 | 06:43 PM
allmtr's Avatar
Default how to make an obd-1 b16 work...
i got a 96 hatch which is obd-2 and i got a b16 thats obd-1. i know its alot of hastle, but how would you make it work without getting the harness?
thanx for any help
Old Jun 30, 2002 | 06:44 PM
JaeOne3345's Avatar
Default Re: how to make an obd-1 b16 work... (allmtr)
sell the obd1 distributor..get an obd2 dist...uhh..doesnt obd2 have some sensor on the oil pump? someone else add more
Old Jun 30, 2002 | 10:00 PM
TurboBumblBee's Avatar
thanx for any help
i think getting the harness is the easiest way of doing it.. remember that the ecu determines wheither its obd1 or obd2 not the engine.. we swapped an obd b18c1 in a friends 93 civic hatch and got an obd1 ecu and everything works perfect.. now going back can get harder ive heard.. good luck
Old Jun 30, 2002 | 10:02 PM
JaeOne3345's Avatar
Default Re: how to make an obd-1 b16 work... (95CivicEX)
i say u just spend the cash on a jumper and obd1 ecu and run obd1
Old Jul 1, 2002 | 12:53 AM
.Ryan's Avatar
Don't Trust Anyone
Default Re: how to make an obd-1 b16 work... (JaeOne3345)
You just need a bottle of DOT approved VTEC Fluid.
Old Jul 1, 2002 | 09:14 AM
allmtr's Avatar
Default Re: how to make an obd-1 b16 work... (SpoonSportsEF7)
thanx for the replys. i can get all the parts i need for free or cheap. im just curious what they are.
Old Jul 1, 2002 | 10:36 AM
Kamin's Avatar
you need to convert to obd I i belive. (the ecu)
Old Jul 1, 2002 | 10:46 AM
dogpile5's Avatar
25 Year Member
Default Re: how to make an obd-1 b16 work... (KAMiN)
whatever gen obd (ecu) you use, make sure the distributor (this can be bypassed if you want to rewire the dist plugs), fuel injectors, o2 sensors, and map sensor match.
neone else?
Old Jul 1, 2002 | 07:01 PM
allmtr's Avatar
Default Re: how to make an obd-1 b16 work... (dogpile5)
thats alot of help. thanx again
Ryan bud
Dec 12, 2012 01:09 PM
No VDUBS here in206
14
Dec 24, 2008 09:02 PM
Mr.Chow
Dec 8, 2008 09:09 AM
mcloven
Jun 30, 2008 06:54 PM
topherchris
Sep 26, 2007 07:30 PM
