REDLINE HELP
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPDINGTEG91 »</TD></TR><TR><TD CLASS="quote">I HAVE A 1991 INTEGRA ALL STOCK REBUILT MOTOR </TD></TR></TABLE>
sounds like you have a stock motor. how about more detail in your posts next time?
i'd like to redline wherever power falls off. and the only way to determine that is on a dyno with engine management. crazy idea i know.
If you wanted to raise the redline on your engine, the time to decide that was BEFORE you rebuilt the engine.
In which case you would have installed aftermarket rod bolts, possibly upgraded connecting rods and dual coil valve springs. This would allow you to safely rev higher.
As some of our fellow HT members have already stated, there is no point in reving to 9000 if your engine quits making power at 7000. Better to shift and get back into a rev range that makes maximum power.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPDINGTEG91 »</TD></TR><TR><TD CLASS="quote">its rebuild with all after market </TD></TR></TABLE>
Oh ok that clears it up.
Come on man, If your going to lie at least edit your origional post.
