Wiring question...Need some help!
Old Jan 14, 2008 | 04:30 AM
insomniac791's Avatar
Default Wiring question...Need some help!
I have a 91 Si I am putting in a 95 stroked lsvtec. I am running a DTA standalone engine management to will completely control the motor and all sensors on it so I have removed the factory Honda ECU.
My question is what is controlled through the ecu that will not work now...Such as fuel pump? or anything else?
FYI
I am running no A/C
No Heater
No radio
No emissions
Old Jan 14, 2008 | 10:18 AM
Anyone?
Old Jan 14, 2008 | 10:35 AM
twiztid17thninja's Avatar
Default Re: (insomniac791)
not quite sure about everything i am not really familiar with your standalone but some systems don't support vtec.
Old Jan 14, 2008 | 10:57 AM
JustAnotherRex's Avatar
Look up the ECU pin-out for an OBD1 engine and you should find some of your answer there, depending upon what comes and goes from the ECU.
I'm not honestly sure beyond that.
Old Jan 14, 2008 | 10:58 AM
Yea I have that covered..Vtec works off of a switched 12v power. Kinda like a shift light. I am more worried about fuel pump, main relay...etc..
Thanks
Matt
Old Jan 14, 2008 | 11:14 AM
sure sounds like a good project give us a build thread when you are done i would also like to see your spark maps if possible. not gonna use standalone on my civic just curious.
Old Jan 14, 2008 | 11:16 AM
jacoop86's Avatar
the main relay needs a signal from the ecu to activate the fuel pump.
Old Jan 14, 2008 | 12:59 PM
Default Re: (jacoop86)
so I could just run the fuel pump to a toggle switch?
Old Jan 16, 2008 | 04:16 PM
jayswat91's Avatar
throw that bitch on a toggle and be done with it
...it'll work
Old Jan 16, 2008 | 04:18 PM
jayswat91's Avatar
Default Re: (jayswat91)
...after all, i have friends who have vtec wired up on a wide open throttle toggle ...lol, how ghetto is that?! but a fuel pump on a toggle, is actually kinda cool.
Old Jan 16, 2008 | 04:48 PM
haha...vtec on a wide open switch dose not seem like a good idea...i will probably just wire the fuel pump to a remote 12v so It just comes on when I turn the key.....
Old Jan 25, 2008 | 06:55 AM
jayswat91's Avatar
come on man, keep it gangsta
dlx111
Aug 31, 2018 12:27 PM
91stocksi
53
Oct 19, 2012 05:56 PM
blac00si
Jan 20, 2011 10:58 AM
Garage786
Mar 11, 2007 03:00 AM
ATW02SI
10
Jun 25, 2004 05:04 PM
