Quick Motor question
Old Jan 13, 2008 | 11:44 PM
gsrpedro's Avatar
Default Quick Motor question NEED HELP ASAP
like a year ago i bent a valve i have a b16 head and GSR bolck aigh i fix the hed put new racing valves double springs retainers so we put everytin back together turn on the car and ...white smoke comin form the exhaust so we checkd the piston rings and they were bad so we changed them and turn on the car again and still white smoke IDK wut else can it be????? valve seals???cuz just te 2nd and 3rd pistons have oil on top! HELP Plz
Old Jan 13, 2008 | 11:47 PM
I'mStock's Avatar
?Is there oil in the coolant or vice-versa?
Old Jan 13, 2008 | 11:48 PM
gsrpedro's Avatar
Default Re: (I'mStock)
nop
Old Jan 13, 2008 | 11:49 PM
gsrpedro's Avatar
Default Re: (gsrpedro)
and the 2 middle spark plugs have oil
Old Jan 13, 2008 | 11:56 PM
424racer's Avatar
Default Re: Quick Motor question NEED HELP ASAP (gsrpedro)
check your valve seals.
did you have a valve job done when you put the new valves in?
and check your sleeves.
did you cap the rings right. you might be getting blow by on your rings.
Old Jan 14, 2008 | 12:01 AM
gsrpedro's Avatar
Default Re: Quick Motor question NEED HELP ASAP (424racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 424racer &raquo;</TD></TR><TR><TD CLASS="quote">check your valve seals.
yeah we did ...and i didnt have a valve job i might take the head out and take it to the machine shop so they can check the seals and the sleeves if they are bad *** it imma have to fix them
h22apwrd95
Jun 10, 2008 05:45 AM
ITR198
May 7, 2006 08:36 PM
huepowered
Apr 4, 2006 12:10 PM
JoeCDN
Oct 14, 2004 09:50 PM
1.8T_EG
Oct 21, 2002 12:50 PM
