Suspension & Brakes Theory, alignment, spring rates....
TIE ROD BOOT / POWER STEERING LEAK ? CONNECTED SOMEHOW ?
Old Jan 13, 2008 | 10:14 PM
jun tao's Avatar
Default TIE ROD BOOT / POWER STEERING LEAK ? CONNECTED SOMEHOW ?
I dont often drive my 96 integra .. so one day i noticed a big leak and no powersteering left. THen i notice that the tie rod boot is ripped pretty bad. My question is can the leak come out from ripped boot ? if no , what can cause my leak ? i mean it just happened like 2 days ago. kinda strange
THanks for the help.
Old Jan 14, 2008 | 02:26 PM
jun tao's Avatar
Default Re: TIE ROD BOOT / POWER STEERING LEAK ? CONNECTED SOMEHOW ? (jun tao)
yes or no ?????????????????
Old Jan 14, 2008 | 04:24 PM
phatrick2332's Avatar
What happened is your inner tie rod boot ripped, then dirt got onto the steering rack. When the dirt on the rack continue to wear on the seal at the end of the rack it caused a leak. Thus, why you have a torn boot and a leaking rack. Best bet is to replace the rack.
Old Jan 14, 2008 | 10:21 PM
jun tao's Avatar
Default Re: (phatrick2332)
can i just replace the boot ? and the leak will go away ? unless a lhd rack is the same ?
jun tao's Avatar
Default Re: (jun tao)
lhd is the same as a rhd.
Old Jan 15, 2008 | 03:03 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jun tao &raquo;</TD></TR><TR><TD CLASS="quote">can i just replace the boot ? and the leak will go away ?</TD></TR></TABLE>
No.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">unless a lhd rack is the same ? </TD></TR></TABLE>
No.
You're going to have to contact a JDM importer and ask them to pull you a good used steering rack from one of their front end clips.
Old Jan 16, 2008 | 09:21 PM
jun tao's Avatar
Default Re: (Targa250R)
isnt the parts the same ? just flipped ?
Old Jan 17, 2008 | 10:42 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jun tao &raquo;</TD></TR><TR><TD CLASS="quote">isnt the parts the same ? just flipped ?</TD></TR></TABLE>
No. If you flipped the steering rack upside down, the car would turn left when you turn the wheel right - because the top of the pinion is moving in the opposite direction from the bottom of the pinion.
Old Jan 17, 2008 | 07:08 PM
jun tao's Avatar
of course you dont flipp the rack...all youre doing is just replacing the parts. ( seals and whatnot ?) right ?
Old Jan 17, 2008 | 08:24 PM
Targa250R's Avatar
be professional
Sorry, I misunderstood your question.
I've no idea if all the seals and other minor components are the same. You'd think they would be, but you never know until you try.
Old Jan 31, 2008 | 06:24 PM
89ludeguy's Avatar
your seals on your rack could be messed up so you might have to replace your rack n pinion.. i had the same problem with my prelude. i had to replace the rack
Yuta
Nov 14, 2015 05:02 PM
lmike6453
May 30, 2008 04:42 PM
StimpyBoy
Mar 14, 2008 03:18 AM
ForceXVII
Jul 7, 2006 06:56 AM
Rywire
Sep 25, 2004 02:44 PM
