power steering?
Old Jan 13, 2008 | 06:06 PM
nfereorhatch's Avatar
Default power steering?
pulled all the power steering lines, pump, etc. off my 90lx sedan. pulled off everything, all the lines that ran to the rack, even the three fittings that connected the lines to the rack. my dilema is what the hell do i do with the rack now? i searched and found that i need to loop the lines back to themselves but everything i read said two lines and i have three spot to fill, where do i go from here? HELP!!!!!!!!!!!!!!!!!
Old Jan 14, 2008 | 10:07 AM
twiztid17thninja's Avatar
Default Re: power steering? (nfereorhatch)
i am assuming that you are converting to manual steering, what you should do is go buy a manual steering rack from the junkyard. and install that. if you buy a used one be sure to replace the tie rod ends inner and outer and also the plastic bushing. start by removing the rear subframe.
Edit: the manual steering rack is much lighter than the power steering rack
edit: did i say junkyard i meant wherever
Modified by twiztid17thninja at 8:42 PM 1/14/2008
nemesis25
Oct 31, 2008 08:30 PM
honduh8
Aug 27, 2007 03:44 PM
XxslayerxX
Feb 17, 2004 08:55 AM
streetracinghn
Dec 14, 2003 07:41 PM
