Making a 3" Exhaust Quiet? please help.
Old Jan 13, 2008 | 03:39 PM
azVTECaccord's Avatar
Default Making a 3" Exhaust Quiet? please help.
Well I'm in the final steps of installing all my turbo goodies on my LS integra & well, the exhaust is way to f'n loud. There is no resonator on the exhaust that I have, but I'm not sure if that will even help quiet it down at all (usually they just smooth out the sounds so it's less raspy)? It has a skunk2 3" muffler & it's way to loud for my style...
Basically I want a VERY quiet 3" muffler, I'd rather hear the turbo spool that listen to some loud obnoxious exhaust. What is the most quiet 3" muffler that I can use? & where can I get it without spending an arm & a leg. I don't even mind some mild flow restriction/power lose/slightly slower spool times if I can just get it quiet! PLEASE ADVISE
& yes I searched... THANK YOU HONDA-TECH
Old Jan 13, 2008 | 03:44 PM
AspectIndustries's Avatar
Default Re: Making a 3" Exhaust Quiet? please help. (azVTECaccord)
Use the search option.
"quiet exhaust" "quiet muffler" etc..Theres many threads out there, thats been very helpful.
I myself, would love to tell you, but I think enough is enough for me. GL..
SEARCH
Old Jan 13, 2008 | 03:48 PM
vietjdmboi's Avatar
so you started your car while still finishing your turbo install?
Old Jan 13, 2008 | 05:32 PM
HiProfile's Avatar
Default Re: (vietjdmboi)
Stuff 2 thin resonators in the 'tunnel', then get something like an Apexi WS2 80mm muffler. I'm unsure if they are baffled or straight-through, but from what people say they're the most quiet you'll find from a 3". I know the 60mm I had on my old hatch was very quiet, as I had to run a day w/o the muffler.
Old Jan 13, 2008 | 05:51 PM
1dumbscreenname's Avatar
Default Re: Making a 3" Exhaust Quiet? please help. (AspectIndustries)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AspectIndustries &raquo;</TD></TR><TR><TD CLASS="quote">Use the search option.
SEARCH</TD></TR></TABLE>
My Profile | Member List | iServe | Garage | Search
You are logged in as 1dumbassscreenname, Log out | Recent Topics
Error
» No Results Found
Your search for quiet exhaust returned no results.
Please try different search criteria or a different data set.
» Go Back
Powered by ZeroForum 2.1.2b. ©2005 RelyNet, Inc.
and the search for quiet muffler came back with this
https://honda-tech.com/zerothread?id=2137016
lets try and help this guy out, I am interested too
Old Jan 13, 2008 | 06:06 PM
ESP.net's Avatar
1' long resonator or 2 small ones back to back with about 4" gap in between and a 3" vibrant oval muffler and call it a day
Old Jan 13, 2008 | 06:07 PM
I have... many many mixed results, trying to figure out what's good info & what's not...
here's some of the other links I've found for reference:
https://honda-tech.com/zerothread?id=1983600
https://honda-tech.com/zerothread?id=1981939
https://honda-tech.com/zerothread?id=1943086
http://vids.myspace.com/index....10749
http://stores.channeladvisor.c...=8984
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietjdmboi &raquo;</TD></TR><TR><TD CLASS="quote">so you started your car while still finishing your turbo install?</TD></TR></TABLE>
Yes, hot side piping removed on stock injectors/ecu until everything including the exhaust is finished, driven maybe 4miles for some minor welding under NO BOOST The car won't be running on boost till next week after the tune.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">Stuff 2 thin resonators in the 'tunnel', then get something like an Apexi WS2 80mm muffler. I'm unsure if they are baffled or straight-through, but from what people say they're the most quiet you'll find from a 3". I know the 60mm I had on my old hatch was very quiet, as I had to run a day w/o the muffler.</TD></TR></TABLE>
thank you sir for a nice response, I will look into it.
Old Jan 13, 2008 | 06:13 PM
one more I found, & thank you people that have actually been helpful. Sound clips are a big plus!
https://honda-tech.com/zerothread?id=1959038
Old Jan 13, 2008 | 08:45 PM
HiProfile's Avatar
Default Re: (azVTECaccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azVTECaccord &raquo;</TD></TR><TR><TD CLASS="quote">Yes, hot side piping removed on stock injectors/ecu until everything including the exhaust is finished, driven maybe 4miles for some minor welding under NO BOOST The car won't be running on boost till next week after the tune.</TD></TR></TABLE>
Boost or not, if you're letting the turbo freewheel ('powering' the exhaust with no load on the compressor), you're already set to do damage. W/o any load on the compressor can cause bearing damage.
If you just have to run it, you should have everything connected besides one clamp on the charge pipes, remove the WG spring, and possibly create a small, controlled exhaust leak. Just to spew some numbers, you've let your turbo freewheel for probably 400,000 revolutions of it's shaft.
Old Jan 14, 2008 | 12:45 AM
riceball777's Avatar
Default Re: (HiProfile)
sound all depends on the size of the muffler
if you run a stupid small round muffler or a small oval muffler its going to be loud
i have a full 3" turbo back exhaust and no cat no resonators and i run a huge turbo and make about 500whp and the car is super quiet
why
because i run a large straight through magnaflow oval muffler 5x11 oval with a 22" body
Old Jan 14, 2008 | 03:17 AM
4thgenhtch's Avatar
Default Re: (riceball777)
I actually ran a summit 3" turbo Muffler Dirt CHeap and QUIET!!
my vid thats full 3" exh, down, no cat, res, just that muffler only cost like 40 somthing bucks ...
thats also in a **** can crx so it would be way quiet in a real car...
http://videos.streetfire.net/v...b.htm
Modified by 4thgenhtch at 6:31 AM 1/14/2008
Old Jan 14, 2008 | 06:56 AM
red_crx's Avatar
Default Re: (4thgenhtch)
I think that sometimes it varies on turbo size and or probably how long the exhaust is. For example on my old crx I first had straight pipe all the way back with a 22" resonator in the middle; still very loud. Then I added a Apex 3" n1 at the end it it made it pretty quiet. Now on my integra its a different story; I ran staright 3" pipe all the way back and added a 3" magnaflow 20"-22" body and its super quiet, until the wastegate opens
Old Jan 14, 2008 | 07:04 AM
fast2camciv's Avatar
i am going from open downpipe, to a full 3" system with a 22" resonator and a magnaflow...im sure its going to be night and day!
Old Jan 16, 2008 | 11:38 AM
Cole D's Avatar
I have a apexi univeral 3 in, 18 in resonator and a catco cat and my car is extremely quiet. T1 said its the quietest turbo 3 in exhuast he has ever heard
Old Jan 16, 2008 | 11:42 AM
blinx9900's Avatar
Default Re: Making a 3" Exhaust Quiet? please help. (1dumbassscreenname)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1dumbassscreenname &raquo;</TD></TR><TR><TD CLASS="quote">
Error
» No Results Found
» Go Back
lets try and help this guy out, I am interested too</TD></TR></TABLE>
You are logged in as blinx9900, Log out | Recent Topics
Honda-Tech.com » Search » 217 topics found
» Search Results
Your search for quiet exhaust returned 217 results.
*LETS TRY AND SEARCH THE ARCHIVES NEXT TIME *
Old Jan 16, 2008 | 03:52 PM
protec77's Avatar
Use a Silencer
Old Jan 16, 2008 | 09:16 PM
blinx9900's Avatar
Default Re: Making a 3" Exhaust Quiet? please help. (protec77)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by protec77 &raquo;</TD></TR><TR><TD CLASS="quote">Use a Silencer</TD></TR></TABLE>
ok seriously GTFO.
Old Jan 16, 2008 | 10:39 PM
Default Re: Making a 3" Exhaust Quiet? please help. (blinx9900)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 &raquo;</TD></TR><TR><TD CLASS="quote">
» Search Results
No kidding huh. Such sad sad kids..
Last time I recalled for the past few years alone, there have been like 1 new thread a week! People are just lazy to search.......
....1dumbassscreenname....Learn how to search dude, seriously...lol..It will save you headaches...
Scotty Dosent Know
Oct 9, 2012 08:15 PM
Broertje
16
Mar 6, 2012 11:37 AM
thambi23
Mar 20, 2008 06:06 PM
CivicSi06
Aug 21, 2002 01:03 AM
