Honda S2000 Honda S2000
F20C max rpi and power
Old Jan 13, 2008 | 02:16 PM
figor's Avatar
Default F20C max rpm and power
Hy, I'm from Croatia and we'r doing some car for hill climb vith S2k engine, so I'm wondering where is the rew limit???? With which modifications can I expect a safe 10000rpm and/or about 300 HP????
We talk about NA tuning....
Hy from Zagreb
Modified by figor at 3:47 PM 1/13/2008
Modified by figor at 5:02 PM 1/14/2008
Old Jan 13, 2008 | 02:31 PM
LAS2K's Avatar
Default Re: F20C max rpi and power (figor)
Hey I've been to Zagreb! Croatia is fvcking awesome!
300 NA HP is going to be very difficult. The only 300hp NA f20/f22 i've seen is the 2.5 liter stroker kit that inlinepro offers.
http://www.s2ki.com/forums/index.php?showforum=148
this website is going to have a lot more info.
Old Jan 13, 2008 | 02:46 PM
figor's Avatar
ok, thanks for nice pics...but stroker kit is not an option....we are limited to 2.0l because of the class regulations....
I'm wondering which components could brake first...we are aiming in some 10000 rpm.
what's the durability of the stock engine? 200.000km? we need about 10.000 km per season (engine rebuild)
Modified by figor at 5:45 AM 1/14/2008
Old Jan 13, 2008 | 03:20 PM
papa5murf's Avatar
Default Re: (figor)
First I was to thank Dinamo Zagreb for giving us (Arsenal) Eduardo Da Silva for £7.5 million. (which I think is a steal)
Secondly. You're not going to get 300 NA rwhp in the s2000 without a stroker kit and major extra work. However, getting a stroker kit will also reduce your ability to rev up to 10k rpms reliably.
You could always go the with gears and some good tuning with basic I/H/E.
Old Jan 13, 2008 | 03:33 PM
figor's Avatar
ok, don't bother with power....which components could break at or below 10k rpm???
do we have to change con rods, retainers, valve springs, valves???
10000 rpm isn't hard to get, but reliable 10k that is another story....
So car is going to be solo for racing - hill climb and we want to rev it high.... what modifications can be made to achieve that , we where thinking of camshafts, ITB and complete intake and exhaust modified to higher revs, standalone.
Modified by figor at 5:50 AM 1/14/2008
Old Jan 13, 2008 | 04:38 PM
Black S2K's Avatar
The bottom end of the F20/22 is pretty solid. Just port/polish the head and build it then throw some itb's on it and have it tuned; you should see some decent gains. Dont forget the basic stuff either like header, tp, exhaust and intake. And if you take the rev limiter off you can rev the stock f20 to 10k its just not good for it. I wouldnt recomend reving it past 9k if you want it to last even if the head is built.
Old Jan 13, 2008 | 04:56 PM
figor's Avatar
Default Re: (Black S2K)
this is some answer..
But, what component of the botom is weakest??? CONRODS??? Or engine botom, or....
Old Jan 13, 2008 | 08:22 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (figor)
the bottom end is forged...
however i think the F20/22 would not be a good choice for a up hill race. unless you slapped a GT28 turbo to it. these motors are lacking what is called TORQUE and you will need that going up hill
Old Jan 13, 2008 | 10:04 PM
ABCVTEC's Avatar
Default Re: (S@nt0s)
Just about every 2.0L car is going to lack torque.. Unless you can get a 2.0L factory turbo'd motor. Are those an option?
Old Jan 13, 2008 | 10:23 PM
LAS2K's Avatar
Default Re: (ABCVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABCVTEC &raquo;</TD></TR><TR><TD CLASS="quote">Just about every 2.0L car is going to lack torque.. Unless you can get a 2.0L factory turbo'd motor. Are those an option?</TD></TR></TABLE>
came standard in my car.
Old Jan 14, 2008 | 05:01 AM
papa5murf's Avatar
Default Re: (LAS2K)
ITB's won't do much, and tuning them isn't easy. Camshafts won't do much either.
Since you don't want to go turbo, nor do you want to get a stroker kit.
If it was me, I'd change the FD gear to 4.77, J's Racing intake, J's racing header, J's racing 70mm RR exhaust, AEM EMS or HKS F-con V Pro for tuning. And call it a day.
Old Jan 14, 2008 | 07:05 AM
Black S2K's Avatar
Default Re: (papa5murf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papa5murf &raquo;</TD></TR><TR><TD CLASS="quote">ITB's won't do much, and tuning them isn't easy. Camshafts won't do much either. </TD></TR></TABLE>
I know but It will add atleast something.
Old Jan 14, 2008 | 07:34 AM
envee's Avatar
He said it was a class limitation for the 2.0. So im assuming everyone else will have the torque handicap. Skunk2's ownwebsite says you will get a max of 15hp and 10tq from their stage 3 cams. Not enough for some of us to justify but if he is going ems and all that jazz, he can get it tuned for them and 15 hp is still 15 hp. And reliability is important but if it is for seasonal race car then it can be rebuilt after each season, I don't see 10k rpm as being a f20 killer just useless without support. I dont think you will come close to 300 but maybe 250+.
Old Jan 14, 2008 | 03:17 PM
figor's Avatar
Has anybody some example of S2000 NA tuning project??? Some links???
Old Jan 14, 2008 | 03:22 PM
LAS2K's Avatar
Default Re: (figor)
the link i provided has many links to NA threads.
cghorr01
Aug 19, 2009 07:17 AM
CRXherbie91
Jun 10, 2008 12:55 PM
97turboteg
Dec 11, 2005 08:15 PM
red95integ
Sep 28, 2004 06:03 PM
slowone
Sep 5, 2003 07:52 PM
