Stroker Kit ?'s
Old Sep 25, 2004 | 03:24 AM
red95integ's Avatar
Default Stroker Kit ?'s
Im about to go boost and im looking for forged internals and i ran across a stroker kit. I was looking at it and they are pretty expensive. I was wondering is there a huge advantage for a stroker kit, or would i be better just getting forged internals and put that money some where else? Any advise would be helpful. Thanks
Old Sep 25, 2004 | 06:46 AM
batmang yO!
Guest
Posts: n/a
Default Re: Stroker Kit ?'s (red95integ)
Well in one word... Torque!
Basicly a stroker kit increases the stroke of the pistons making them longer which increases the engines mechanical advantage at the crank in other words Torque. A stroker kit also increases the engines displacement and when all you have is 1.8 thats a definate plus. also you should know that when stroking out an engine it usualy causes it to make peak power at a lower or slightly lower RPM, and raises the power output throught the whole powerband. I would love to get a stroker kit for my Gs-r but like you said, there expensive, epecialy when you consider how much power you gain for the $buck$ compared to a turbo, unless $$ ain't a problem for you then don't waste your time and money on a stroker kit, just boost it!
A stroker kit is ideal for an all motor setup. if you got the green that is!! but don't get me wrong a stroker kit with a turbo aswell! Damn! you got some serious potential there!
Modified by Beavis at 8:08 AM 9/25/2004
Old Sep 25, 2004 | 08:06 AM
greaseball's Avatar
if you were already thinking of forged internals why not bore your block and sleeve it instead of the stroker kit.
Old Sep 26, 2004 | 11:10 AM
red95integ's Avatar
Default Re: Stroker Kit ?'s (greaseball)
because a boring it out will not give you the same affect as a stroker kit. The stroker kit also has forged internals.
Old Sep 28, 2004 | 03:23 PM
greaseball's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red95integ &raquo;</TD></TR><TR><TD CLASS="quote">because a boring it out will not give you the same affect as a stroker kit. </TD></TR></TABLE>
how so? boring out the block increases displacement. stroking a block also increases displacement. plus if you wanna make big power, you're gonna wanna sleeve the block and you gotta bore it for the sleeving anyway...so why waste money on a stroker kit??? and is this a street car? if it is, better think of reliability.
Old Sep 28, 2004 | 03:48 PM
tommymoose's Avatar
While they both increase displacement, boring out the block would be more favorable because the bore/stroke ratio would get closer to square allowing higher revs. The B18's already start off with a larger stroke than bore, so boring would bring it closer to square as opposed to stroking it out and getting an even "worse" ratio. The longer the stroke compared to the bore, the lower you can safely rev your engine because it puts more force on the cylinder walls. Now high revs arent really necessary if your making power lower, but its just something to think about. I would think that there is a reason all(if not all, almost all) F1 cars have a 1:1 bore:stroke ratios.
Old Sep 28, 2004 | 03:51 PM
greaseball's Avatar
Default Re: Stroker Kit ?'s (tommymoose)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tommymoose &raquo;</TD></TR><TR><TD CLASS="quote">While they both increase displacement, boring out the block would be more favorable because the bore/stroke ratio would get closer to square allowing higher revs. The B18's already start off with a larger stroke than bore, so boring would bring it closer to square.</TD></TR></TABLE>
exactly! good info man. oh, and by the way..."skateboarding is not a crime"
Old Sep 28, 2004 | 03:52 PM
tommymoose's Avatar
haha I keep editing my post to try and improve it. Skateboarding is cool and all but rollerblading is the way to go
Old Sep 28, 2004 | 05:17 PM
Burnt Orange Teg's Avatar
how much will it increase the displacement if you bore it out. On average.. i know there are diffrent amounts you can bore it out.
Old Sep 28, 2004 | 05:34 PM
whiteyGSR's Avatar
ew...rollerblading....
anyway, i was gonna grab a stroker kit as well, but for reliability, it's easier for me to have our local tuner shop set me up with a high compression all-motor set-up. also it's a bit cheaper because unless you plan to DIY, a stroker kit installed isn't cheap. i can probly get all the head work i need done (porting, valve train upgrade) for the price of just the stroker kit.
Old Sep 28, 2004 | 06:03 PM
dick_213's Avatar
Default Re: Stroker Kit ?'s (Burnt Orange Teg)
it really is a simple equation, to find the displacement, you just take your stroke and bore specs and plug them into the equation to volume of a cylinder and from there it is a cake walk.
00EckoSI
Jan 10, 2010 05:27 PM
cghorr01
Aug 19, 2009 07:17 AM
dropped like its hot
Apr 29, 2005 11:30 AM
