b16 wont start....
Old Jun 30, 2002 | 03:53 PM
brent_G's Avatar
Default b16 wont start....
Alright tried to start my b16 in my hatch today...first time since i did the swap. Alright it ran really rough with gasing for like 20 seconds...when i felt the headers. Only cylinder 1 and 2 were firing. Alright what are my possibilties of somethign being wrong? for one i saw i have a head gasket leak...pissed about that. 2 i dont know anything about this motor. SO give me some ideas...
Old Jun 30, 2002 | 03:56 PM
thashadow's Avatar
Default Re: b16 wont start.... (screamincivik)
check fuel pump, distributor, spark plugs....
my b16 gives me probs every once in a while.
Old Jul 2, 2002 | 11:08 AM
Turbo EX's Avatar
Make sure the plug wires are in the right cylinders, are all the injectors working?
Old Jul 2, 2002 | 11:56 AM
01-0720's Avatar
Default Re: b16 wont start.... (Turbo EX)
check all and any ground wires sounds stupid but it will make a
big difference. It always can be somthing stupid with hondas goodluck
Old Jul 2, 2002 | 01:15 PM
The_Head's Avatar
I had to replace my internal coil on the distributor yesterday, but you had 2 cylinders firing... so it probably isnt a bad coil
Old Jul 2, 2002 | 01:32 PM
sammysnakes's Avatar
sounds like you have bad cables and/or plugs
Old Jul 2, 2002 | 10:27 PM
DOHCtorTHRUST's Avatar
Default Re: b16 wont start.... (chainsaw)
change the injectors....... i had the same problem since my motor was siting on a crate for who knows how long....... once i changed it, the motor ran fine..... if it still doesnt work, do a vavle adjustment...... maybe the valves arent openening....
Old Jul 3, 2002 | 12:11 AM
brent_G's Avatar
Default Re: b16 wont start.... (DOHCtorTHRUST)
thanks for all your help fellas ill try all of the above.
Old Jul 3, 2002 | 12:37 AM
95hatchy's Avatar
New User
check the firing order and timing and make the dist. is the same generation
good luck
my gave me troubles too
Old Jul 3, 2002 | 01:45 AM
Kamin's Avatar
Default Re: b16 wont start.... (95hatchy)
replace the spark plugs!
StreetEG
10
Jul 25, 2005 11:48 AM
boosted96midorihatch
11
Jul 31, 2004 08:20 PM
RussHondaCRXVtec
Dec 17, 2003 10:40 PM
90_Civic_Hatch
10
Aug 9, 2002 11:05 AM
prjctCIVIC
Mar 22, 2002 07:51 AM
