Need help on installing Koni Yellows/06-DC5
Old Jan 12, 2008 | 12:50 PM
Desperado's Avatar
Default Need help on installing Koni Yellows/06-DC5
A freind and I are going to install a set of Koni yellows on my 06 RSX. I have searched Club RSX and honda-tech for a DIY or anyhelpful info on trying to put them on and have found nothing. I am wondering because it looks like top of the strut tower has to be cut.
Old Jan 12, 2008 | 01:17 PM
dc5Aspec'd's Avatar
Default Re: Need help on installing Koni Yellows/06-DC5 (Desperado)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Desperado &raquo;</TD></TR><TR><TD CLASS="quote">A freind and I are going to install a set of Koni yellows on my 06 RSX. I have searched Club RSX and honda-tech for a DIY or anyhelpful info on trying to put them on and have found nothing. I am wondering because it looks like top of the strut tower has to be cut.</TD></TR></TABLE>
Cut? Definitely don't cut anything! The struts just need to be unbolted.
Old Jan 12, 2008 | 02:57 PM
j-bird's Avatar
Default Re: Need help on installing Koni Yellows/06-DC5 (dc5Aspec'd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc5Aspec’d &raquo;</TD></TR><TR><TD CLASS="quote">
Cut? Definitely don't cut anything! The struts just need to be unbolted. </TD></TR></TABLE>
Don't listen to this guy.
U have to cut the top of the strut because the koni yellow is a strut insert. U also have to drill a hole in the bottom as well to bolt it in there.
Old Jan 12, 2008 | 03:41 PM
Desperado's Avatar
Default Re: Need help on installing Koni Yellows/06-DC5 (j-bird)
I saw something about that. Know of any DIY instructions.
Old Jan 12, 2008 | 05:09 PM
OSK Automotive's Avatar
http://www.hondatuningmagazine....html
http://www.civicforums.com/for....html
Those are both on EM2s but its pretty much the same thing.
Old Jan 13, 2008 | 09:14 AM
j-bird's Avatar
Default Re: Need help on installing Koni Yellows/06-DC5 (OSK Automotive)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OSK Automotive &raquo;</TD></TR><TR><TD CLASS="quote"> http://www.hondatuningmagazine....html
Those are both on EM2s but its pretty much the same thing. </TD></TR></TABLE>
The second one was the one i was looking for and couldn't find it. Thanks for posting it up
Old Jan 13, 2008 | 11:28 AM
dc5Aspec'd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j-bird &raquo;</TD></TR><TR><TD CLASS="quote">
U have to cut the top of the strut because the koni yellow is a strut insert. U also have to drill a hole in the bottom as well to bolt it in there. </TD></TR></TABLE>
My mistake, why do they make you do that? That's pretty beat if you have to cut ****, just to put a strut in
Old Jan 18, 2008 | 04:52 PM
j-bird's Avatar
My mistake, why do they make you do that? That's pretty beat if you have to cut ****, just to put a strut in </TD></TR></TABLE>
They make it as a strut insert so its cheaper.
Old Jan 19, 2008 | 12:29 AM
DC54LIFE's Avatar
I have koni in my 02 rsx. Had to cut the top just like you though you did. I then pulled out the strut and replaced it with the new one. Honda makes you do this for some reason unless your doing coilovers. Suck I know but its necessary. Also you will probably have to drill a hole in the bottom to release the pressure of the strut. Thats what I had to do to mine. good luck.
Old Jan 19, 2008 | 07:55 PM
Todd00's Avatar
I said I don't want a title!
Koni provides decent directions for the front strut modification. Did you not get the paperwork?
FWIW, Koni does this method on a lot of strut applications.
Old Jan 20, 2008 | 12:33 AM
concept11253's Avatar
Make sure your carefully with your koni's. They blow out so easy especially if your slammed. I have blown a couple of front koni's now. Well worth it but they blow out easy. And yes your have to cut the top of the strut off and drill a hole in the bottom to screw the koni in.
NyCSnEaK
May 6, 2011 05:14 PM
ACCORDPRIDE
Jan 23, 2010 07:18 AM
99SlammedCivic
Suspension & Brakes
Apr 29, 2008 08:22 AM
pjr710
Mar 17, 2007 07:25 PM
No-Gi
Jul 27, 2003 06:50 PM
