question about k20a VS k20A2
yes.
but it's really not worth it unless you're baulin out of control and have all the time in the world.
the two are extremely similar. get some new cams, i/h/e and you'll be making good power.
id like to know also. does anyone know the real differences between the two? i know the transmissions on the k20a are much stronger and are race built...different cams....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rajinazn06 »</TD></TR><TR><TD CLASS="quote">sorry but what is i/h/e thanks</TD></TR></TABLE>
intake/header/exhaust, youll hose a k20a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rajinazn06 »</TD></TR><TR><TD CLASS="quote">what cams do you recommend</TD></TR></TABLE>
what are you looking to do with the car? thats the biggest/first question
basically, if you have a k20a2, keep it man
just build the a2 it will be cheaper and faster. Its not a big difference as say a gsr and type r engine. They are both very similar just the k20a is more built for racing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twinturbo03gsR »</TD></TR><TR><TD CLASS="quote">new to the k20 motors which is the difference between k20 and k20a which car they belong to.</TD></TR></TABLE>
K20z1 belongs to an '05-'06 RSX Type-S and the K20a belongs to the Type-R model.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twinturbo03gsR »</TD></TR><TR><TD CLASS="quote">and why the 05-06 rsx type s has more hp than the yearsd before</TD></TR></TABLE>
I believe they included Type-R cams and a few other things, but I'm not quite sure. Search for more information.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pat_S »</TD></TR><TR><TD CLASS="quote">
I believe they included Type-R cams and a few other things, but I'm not quite sure. Search for more information.</TD></TR></TABLE>
You are correct... they are typeR variants... assuming they are typeR cams. k20z1 also has shorter gear ratio then the 02-04. Other then that the rest is aestethics.
Modified by risktypeS at 10:47 PM 1/12/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by risktypeS »</TD></TR><TR><TD CLASS="quote">
You are correct... they are typeR variants... assuming they are typeR cams. k20z1 also has shorter gear ratio then the 02-04. Other then that the rest is aestethics.</TD></TR></TABLE>
I believe the '02-'04 models have a 4.4 final drive while the '05-'06 have a 4.7 final drive.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NashDishesDimes »</TD></TR><TR><TD CLASS="quote">id like to know also. does anyone know the real differences between the two? i know the transmissions on the k20a are much stronger and are race built...different cams....</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NashDishesDimes »</TD></TR><TR><TD CLASS="quote">I think he asked the difference between the k20a and the k20a2? anyone know?</TD></TR></TABLE>
No, I think you asked that question.
Modified by Pat_S at 10:19 PM 1/12/2008
I believe the '02-'04 models have a 4.4 final drive while the '05-'06 have a 4.7 final drive.</TD></TR></TABLE>
yes it does but the 05-06 has a lower final gear ratio.
Lets say you are at 3000rpm at 60mph with a 4.4 now with a 4.7 you are now at 3300rpm at 60mph
that is why i prefer the 02-04 tranny, especially for boost
that is why i prefer the 02-04 tranny, especially for boost</TD></TR></TABLE>
Oh, I understand now... Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by risktypeS »</TD></TR><TR><TD CLASS="quote">np, i know it's a bit confusing.</TD></TR></TABLE>
engines can be
engines can be
i have a 99 nbp gsR and im going to sell it because i want a nbp 05-06 rsx type s. i want to boost it depending on how much boost i run and what i do will the car be oil change and key start worry free. or should i just keep the gsR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twinturbo03gsR »</TD></TR><TR><TD CLASS="quote">i have a 99 nbp gsR and im going to sell it because i want a nbp 05-06 rsx type s. i want to boost it depending on how much boost i run and what i do will the car be oil change and key start worry free. or should i just keep the gsR </TD></TR></TABLE>
Huh?
Huh?
sell your swap for about 3200
purchase k20a swap for about 5600
for approx 2400 you get:
better header
better cams already installed
better valvetrain already installed
better/higher compression pistons already installed
better intake manifold already installed
better/smaller diameter crank pulley already installed
better/higher final drive already installed
better/more aggressive gearing already installed
better differential already installed
better valve cover LOL
better dip stick LOL
better overall powerband
better than aftermarket upgrade options reliability issues (lots of people experiencing timing chain slap and oil pump failure with aftermarket cams)
better/higher resale value of swap
better/matched ECU for your engine setup (PRC ECU)
seems like a decent deal to me.
better header
Yeah but i want the newer body style vehicle. i do have a question about the k20a and the k20z1 in the 05-06 whats the big difference. i also think that i could just purchase the type r lsd and the final drive or is the type r tranny better over for boosting that is.
in 05/06 tranny is the same as type r w/o lsd, The FD is 4.7 in 05/06 compared to i think its 4.3 in 02-04. the z1 has more hp, type r cams and i think something else im missing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpEeDyX »</TD></TR><TR><TD CLASS="quote">in 05/06 tranny is the same as type r w/o lsd, The FD is 4.7 in 05/06 compared to i think its 4.3 in 02-04. the z1 has more hp, type r cams and i think something else im missing</TD></TR></TABLE>
Just repeated what I said, haha.
b18pwr
10
Sep 23, 2009 05:28 PM
hype_R
Mar 7, 2008 08:37 AM
mikeycivic
Mar 11, 2007 09:29 AM
