Leaking sunroof.
Old Jan 11, 2008 | 08:15 PM
IVIcGurk's Avatar
Default Leaking sunroof.
i got in my car today after the thunderstorms we had in NJ and noticed i had a wet passenger side rear seat. I'm assuming its the sunroof drain on that side of the car, having never cleaned a sunroof drain before i was wondering where it ended, and any other ideas as to the source of the leak would be helpful too
Old Jan 11, 2008 | 08:30 PM
BlueJdm's Avatar
Default Re: Leaking sunroof. (IVIcGurk)
I had this happen to me a while back. The drain hole is behind the rear bumper just below the quarter panel. So you would have to remove the bumper to get to it. But I just opened the sun roof and poured hot water (not boiling but close) on the track. I also had my car parked on an incline to make sure the water went back toward the clogged tube.If works you should see water running out of your bumper just behind your rear tire.
Old Jan 11, 2008 | 09:45 PM
IVIcGurk's Avatar
Default Re: Leaking sunroof. (BlueJdm)
awsome thanks. ill pull that pig up on ramps and try it in the morning.
Old Jan 12, 2008 | 02:30 PM
spAdam's Avatar
Loved
Community Favorite
Get some water in there and blow it out with an air hose... try not to use full pressure to avoid blowing the hose off the fittings. That more than likely won't happen, but its best to play it safe.
You might also want to look at your sunroof pan... last week I found this:
That just cost me 250 bones from honda
Old Jan 14, 2008 | 09:54 AM
prelude_h22vtec's Avatar
man woulda sold you mine waaay cheaper
Old Jan 16, 2008 | 10:49 AM
spAdam's Avatar
Loved
Community Favorite
Default Re: (prelude_h22vtec)
Its a civic... if you got one for that, I'll take it
bad 91 teg
33
Oct 1, 2011 02:34 PM
ej1fury
Apr 11, 2009 11:24 AM
JonLude
Feb 28, 2006 05:52 PM
Ronin Integra8
May 25, 2003 08:38 AM
bodiby
Apr 24, 2002 09:31 AM
