How To: fixing sloppy Avid shift linkage
Old Jan 11, 2008 | 07:09 PM
I CRX I's Avatar
Default How To: fixing sloppy Avid shift linkage
heres my tiny contribution to the holy bible of honda-tech i look to constantly for advise. now results may vary depending on the construction of the linkage and whether or not Avid changed there design. please look a the next post being as i could not copy and paste on the original. P.S. if anybody can verify whether or not this will work on any other linkage such as hasport, pleast post it here.
Old Jan 11, 2008 | 07:10 PM
I CRX I's Avatar
Default Re: How To: fixing sloppy Avid shift linkage (I CRX I)
ok well i was contacted by an avid member via IM and they stated there shift linkages were also under warenty but i had to send it to them in order to ge it fixed....this is my daily driver so that was out of the question. buuuut heres my solution. i went to lowes searching for about an hour and i finally found the perfect replacement. now those who apose or have any negative comments about my method can kiss my ***, i only spent 7 bucks total and it worked like a charm. absolutley no sloppy play whatsoever. so heres what i bought: exuse my crappy pics
first you want to get what lowes calls "Well Nuts" the dimesnions you want to get are 5/16, 18
next you want to buy some 5/16/18, 2 1/2" bolts, any longer will not work.
Next you want some 5/16/18 nylon lock nuts
now after removing your old linkage you want to modify (trim with some scissors)the old busings like the one in the next pic on the right.
you want to put everything back just like you took it off, which by the way was easy as pie, although avid welds the end of each nut and bolt, it was a breeze to screw off. you want to put one of the old trimmed bushings in between the 2 well nuts. not only will this stiffen the bitch up but you wont have to worry about anything comming loose do to both the lock nut annd the threading in the well nuts. remember to put the plastic washers back on each side so there is no binding, it wouldnt heart to add some extra lube on them also.
Modified by I CRX I at 8:31 PM 1/11/2008
Old Jan 11, 2008 | 07:22 PM
Crx Jimmy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I CRX I &raquo;</TD></TR><TR><TD CLASS="quote">first you want to get what lowes calls "Well Nuts" the dimesnions you want to get are 5/14, 18
I'm pretty sure you mean 5/16 x18 not 5/14, 18
Old Jan 11, 2008 | 07:32 PM
I CRX I's Avatar
Default Re: How To: fixing sloppy Avid shift linkage (Crx Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">
I'm pretty sure you mean 5/16 x18 not 5/14, 18</TD></TR></TABLE>not sure how you can tell that from those shitty as pics i took but you are correct FIXED^
Old Jan 11, 2008 | 11:17 PM
spastik's Avatar
i wonder if this trick works for the hasports too. i have that problem as well.
nice write up!
Old Jan 12, 2008 | 06:56 AM
GI8U2racing's Avatar
Default Re: (spastik)
I'm definitely not following this at all, can you get some good shots of it assembled?
My HASport is sloppy as crap. I'm gonna get new bushings, but I think it's more than that. I drove a stock Integra, and it feels awesome, so it isn't just the tranny
Old Jan 12, 2008 | 10:31 AM
I CRX I's Avatar
Default Re: (GI8U2racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GI8U2racing &raquo;</TD></TR><TR><TD CLASS="quote">I'm definitely not following this at all, can you get some good shots of it assembled?
My HASport is sloppy as crap. I'm gonna get new bushings, but I think it's more than that. I drove a stock Integra, and it feels awesome, so it isn't just the tranny</TD></TR></TABLE>its really simple, if you look at the last pick i posted, the bushing on the left is the original sloppy avid bushing that i removed which the bolt goes thru, if you look at the first pick i posted, those are what your replacing the originals with, one on the left side of the linkage and one on the right side. now by trimming one of the original busgings, you can place it in the middle of the 2 therefore making 3 points of contact on the joints cylinder, cushioning the linkage even more. i cant really take a pick of it installed being as the bushings arent visible but its really simple and should only take 15-30 mins tops to do.
heres a simple diagram i drew for refference
the green is where the well nuts go and the blue is where the trimmed old bushing goes, the red is where the plastic spacers go, then you bolt eveything up in that order.
Modified by I CRX I at 11:42 AM 1/12/2008
Old Jan 12, 2008 | 02:27 PM
RCautoworks's Avatar
Hasport has a life time warranty, they will fix it or send you a kit to fix it
Old Jan 15, 2008 | 10:00 PM
spastik's Avatar
Default Re: (RCautoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RCautoworks &raquo;</TD></TR><TR><TD CLASS="quote">
Hasport has a life time warranty, they will fix it or send you a kit to fix it</TD></TR></TABLE>
who do you contact for that? mines on my dd so i cant let it go down without having a backup to put on
Old Jan 15, 2008 | 11:52 PM
what do you mean by "sloppy"??
Old Jan 15, 2008 | 11:56 PM
jdm206's Avatar
Default Re: (vega_ROCKS)
when my shift linkage was sloppy i called hasport up and they sent me a repair kit to fit it. it only took me 20 minutes to do
. but im still having a little problem with my linkage rite now.
Old Jan 16, 2008 | 04:13 AM
I CRX I's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vega_ROCKS &raquo;</TD></TR><TR><TD CLASS="quote">what do you mean by "sloppy"??</TD></TR></TABLE>sloppy as in too much shifter free play when in gear.
Old Jan 16, 2008 | 07:41 AM
Default Re: (I CRX I)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I CRX I &raquo;</TD></TR><TR><TD CLASS="quote">sloppy as in too much shifter free play when in gear. </TD></TR></TABLE>
gotcha
having the same problem w/ mine
Was hoping I wasn't the only one
Old Jan 20, 2008 | 07:58 AM
YZFR6's Avatar
Hey, everyone. If you guys have a problem with the knuckle assembly having play. Please feel free to e-mail me at info@avidracing.com. We'll be glad to give you a free replacement knuckle. Or call our toll free 1-866-507-2843. As our products are backed with a limited lifetime warranty. Hope this helps
Old Jan 20, 2008 | 02:19 PM
gringo7718's Avatar
Default Re: How To: fixing sloppy Avid shift linkage (YZFR6AVID)
my shift linkage has a problem with "riveted pin" in the knuckle.
I have always wanted to just grind off the rivet and install a bolt and some bushings.
nice job!
vtecc
Jun 1, 2015 10:53 PM
teamV eg
Feb 7, 2007 07:59 AM
LSEGHATCH
Apr 2, 2005 05:01 PM
Vtec92Civic
Sep 4, 2004 01:11 PM
