tial 60mm and s372
I was wondering if a tial 60mm would be big enough to control wastegate gasses on a top mount manifold , or should i just go with a full race top mount and two 44mm tials. i would love just to run one huge waste gate
if you are using a non divided top mount id immagine the 60 would do you good, if you are running high boost i dont think you need to go that big, if you are going divided, the best way is the pair of gates.
http://www.evans-tuning.com/te....html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paulzy »</TD></TR><TR><TD CLASS="quote">should be more than enough. You wouldn't even need one that big unless you're running seriously low boost on large turbo.</TD></TR></TABLE>
correct
correct
GetawayInMoscow
Sep 12, 2007 12:43 PM
dome
Feb 17, 2007 08:56 AM
turboedc2
May 20, 2005 12:57 PM
