Vafc 2
Can a Vafc be used on a Mass air flow sensor'd car? such as a Mazda miata?
its going turbo and the guy want to install a vafc. i understand the "v" is not gonna be wiried up. I know it works for a Map but can i wire it up to a Mass?
TIA
TIA
I highly doubt it, MAF sensor is more of a flow meter, and MAP of course is pressure. I believe it would need the MAP to work properly, as well as the fact its ment for a vtec equipped honda. Try looking at the safc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6hatchboy »</TD></TR><TR><TD CLASS="quote">I highly doubt it, MAF sensor is more of a flow meter, and MAP of course is pressure. I believe it would need the MAP to work properly, as well as the fact its ment for a vtec equipped honda. Try looking at the safc.</TD></TR></TABLE>
I think he's going to be right on this...
I wouldn't be surprised if there's a way to make it work, but I wouldn't try and mess with it. Easier to sell it and buy the proper tool for the car.
Cool Cool Island Breezes. BOY-EE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bangher4$ »</TD></TR><TR><TD CLASS="quote">Can a Vafc be used on a Mass air flow sensor'd car? such as a Mazda miata?
TIA</TD></TR></TABLE>
No the VAFC will not. The VAFC is setup for speed density (MAP) signal. The SAFC might work with some Mcguyver-ing. There are no wiring diagrams for the SAFC available for miatas as far as I know, however.
You will most likely have to run the car on 2 cylinder mode on the SAFC setting. The coil packs for miatas fire 2 cylinders at a time. Meaning the ignition doesn't operate like a conventional 4 cylinder. I'm almost 100% sure that that's how the coils operate on miatas. This may depend on the year of the miata. I have limited miata knowledge. But I can make one go fast around a track
98civicEX
Jul 2, 2002 07:16 PM
