Garrett Turbocharger Speed Sensor ???
Old Jan 11, 2008 | 10:20 AM
mrlegoman's Avatar
Default Garrett Turbocharger Speed Sensor ???
Garrett just sent a newsletter out about a new turbocharger speed sensor:
http://www.turbobygarrett.com/....html
From their website:
"Comparing boost levels and shaft speed on a compressor map, you can determine the ideal operating conditions to insure peak power over a wider operating range."
Can someone explain this a little bit more?
I understand once you know your wheel speed and boost pressure, you can calculate you air flow with the compressor map. But I also figured you could calculate your location on the map using hp figures too.
Old Jan 11, 2008 | 11:30 AM
sp00led's Avatar
Default Re: Garrett Turbocharger Speed Sensor ??? (mrlegoman)
I noticed an ad in the latest turbo magazine about it. Think it might have been in a sema report.
Old Jan 11, 2008 | 12:39 PM
TiAL's Avatar
you can control boost by shaft speed granted you have a capable EMS
Old Jan 11, 2008 | 02:45 PM
NLR's Avatar
NLR
Default Re: Garrett Turbocharger Speed Sensor ??? (TiAL)
it says it has a 0-5 volt output, is this correct?
Old Jan 11, 2008 | 03:11 PM
GarrettGTBB's Avatar
Banned
Hi mrlegoman-
The new Garrett Speed Sensor readings provide you with a quicker means of plotting your operating conditions on the compressor map. Calculating air mass flow from assumptions for fuel rate and a/f ratio can also be validated by comparison with the turbo speed data plotted on the map.
And, NLR-
Yes, the Garrett Speed Sensor does put out a 0-5 volt output that you can datalog.
I hope this helps!
Old Jan 11, 2008 | 04:51 PM
NLR's Avatar
NLR
Default Re: Garrett Turbocharger Speed Sensor ??? (GarrettGTBB)
great. This means anyone using our ams-1000 can use that to feed our 0-5 volt input for boost based off of shaft speed or throw it into a ems to trigger an output to our decrease input to drop boost if shaft speed exceeds a set point!
Awesome....we were going to develop one but now I dont need to
Old Jan 11, 2008 | 05:12 PM
Turbo-charged's Avatar
Default Re: Garrett Turbocharger Speed Sensor ??? (NLR)
thats awesome. sounds ideal for the rally guys. even cooler it works with the ams-1000!
Old Jan 11, 2008 | 05:43 PM
turbotypeR@SPEC's Avatar
25 Year Member
Default Re: Garrett Turbocharger Speed Sensor ??? (Turbo-charged)
i saw that at pri. very cool
Modified by turbotypeR@SPEC at 8:10 AM 1/19/2008
Old Jan 11, 2008 | 06:25 PM
MidShipCivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GarrettGTBB &raquo;</TD></TR><TR><TD CLASS="quote">Hi mrlegoman-
And, NLR-
I hope this helps! </TD></TR></TABLE>
Of course you have pictures of this product installed ?
How is it installed ?
Old Jan 14, 2008 | 08:21 AM
Banned
Default Re: Garrett Turbocharger Speed Sensor ??? (MidShipCivic)
Both inquiries will be answered on our website by tomorrow (installation instructions and installed photos).
Old Jan 14, 2008 | 08:36 AM
OCALA TURBO PERF's Avatar
What’s the accuracy difference between these easy to install sensors over the ones that read shaft speed? The ones that are installed in the bearing housing that require a groove to be cut into the shaft.
H-allmotorda9
Feb 7, 2010 07:29 PM
GoHybrid
Mar 29, 2009 06:13 PM
B16Drag
Jan 25, 2006 06:59 AM
eg:R
Oct 23, 2005 01:54 PM
rice4life
May 14, 2002 05:45 PM
