D16y8 vs Zc
Old Jan 11, 2008 | 09:12 AM
robs97's Avatar
Default D16y8 vs Zc
What is the diffrence other than jap..... plz list pros and cons..I would be putting this into my 97 civic coupe....want to stay single cam
Thanks
Old Jan 11, 2008 | 09:29 AM
Panda Eg6's Avatar
Default Re: D16y8 vs Zc (robs97)
what zc, the single cam non vtec, or the 1.6l vtec sohc version??
Old Jan 11, 2008 | 09:33 AM
Sic_DA_Nine's Avatar
id stick with the y8..
since you have a decent platform to go off of...
put that money that you were gunna spend for the zc and turbo it..\
the zc is obd0 i believe...and me personally...would rather keep the y8
Old Jan 11, 2008 | 09:35 AM
Panda Eg6's Avatar
Default Re: (Sic_DA_Nine)
a little more info, the single cam sohc zc is almost identical to the usdm d16a6... obd1?? not sure. And the vtec version is obd1 same as the usdm d16z6. The dohc zc both come in obd0 and obd1
Old Jan 11, 2008 | 09:41 AM
robs97's Avatar
I was intrested in the Zc sohc vtec
thanks for all the info
Old Jan 11, 2008 | 09:54 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: (robs97)
Vague topic #85789567895???
Anyways did your stock engine blow up?
Looking for a replacement, or an UPGRADE?
Also do you live in a state that has emissions? If so you will need to do a few wiring changes to trick your ECU into thinking the JDM engine has the CKF sensor.
More info could help us help you.
BTW:
Reliability wise I gate any 96-00 D series engines. They have crap bottom ends that usually develop rod knocks WELL before the older ones do. I don't know if it's oiling issues, crappy bearings, or just crappy builds from the factory, but I'd take a 1988 D16A6 engine over a 2000 D16Y8 engine all day, every day.
Old Jan 11, 2008 | 01:06 PM
MoreBoost!'s Avatar
Default Re: (B18C5-EH2)
why downgrade? stick with the y8 n build up on that
less headaches n work , by going zc route alot of wiring has to be done
Old Jan 11, 2008 | 05:34 PM
robs97's Avatar
I live in socal and yes my engine is shot I dont care about going fast but I do care about torque I hate to be the last one to go I have a few mods all bolt on if I keeo my d16 what you recommened to do to get that torque other that a turbo..?
djxtc65
Jul 26, 2006 04:54 PM
DEVINEER
10
May 27, 2004 03:10 PM
Gant
10
Apr 29, 2004 05:26 PM
after_effx
Apr 17, 2004 10:16 AM
ceLtic
Jan 4, 2004 07:17 PM
