Cages that go THROUGH the dash...how the hell?
Old Jan 11, 2008 | 07:34 AM
.RTErnie's Avatar
Default Cages that go THROUGH the dash...how the hell?
I've seen this several times and never once have I fully grasped how you do this..and if its possible to remove your dash once this has been done?
It could be as simple as... take your hole saw...cut a hole on your dash...route the tube through..voila! But... is this a one time deal? e.g. you route it through, weld it, and then never remove your dash?
Please enlighten me.
Old Jan 11, 2008 | 08:54 AM
redboost10's Avatar
Default Re: Cages that go THROUGH the dash...how the hell? (.RTErnie)
i ran my pillar bars through the "Honda" dash vents, then made two cuts so i can remove my dash in and out. you can kinda see one of the cuts on the right side of the bar.
Old Jan 11, 2008 | 09:09 AM
.RTErnie's Avatar
Default Re: Cages that go THROUGH the dash...how the hell? (redboost10)
I spy a prologger
thanks!
Old Jan 11, 2008 | 01:52 PM
RedheadRacing's Avatar
I did the same thing for my down tubes. Ran them through the vent and cut a big slit so the dash could be pulled out.
Worked pretty well.
Old Jan 11, 2008 | 02:28 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Cages that go THROUGH the dash...how the hell? (RedheadRacing)
we cut the windshield out when rhodes did mine. to answer the other question, the dash is in there for the long haul he hee.
Old Jan 11, 2008 | 06:03 PM
88_DX's Avatar
Default Re: Cages that go THROUGH the dash...how the hell? (boostedcivicsir)
ill let u use my car too figure it out I think its going too be a huge pain
Old Jan 13, 2008 | 03:59 PM
racecar chassis builder's Avatar
* B A N N E D *
Default Re: Cages that go THROUGH the dash...how the hell? (88_DX)
ya do it like that
Old Jan 13, 2008 | 04:17 PM
.RTErnie's Avatar
Default Re: Cages that go THROUGH the dash...how the hell? (racecar chassis builder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racecar chassis builder &raquo;</TD></TR><TR><TD CLASS="quote">
ya do it like that</TD></TR></TABLE>
dash removal?
Old Jan 13, 2008 | 06:03 PM
a1320addict's Avatar
I see it all the time and think it's incredibly unpractical.
I had the front-most corners of the dash notched as to be able to remove and reinstall the dash at any time, looks clean and is functional
Old Jan 13, 2008 | 07:02 PM
BoostedJeff's Avatar
Default Re: Cages that go THROUGH the dash...how the hell? (a1320addict)
Mine goes through the dash, and the dash is not removable, and it sucks, considering I want to swap out dashes, and need to remove the dash in order to cut the old one out.
Next dash will be notched for the bars for sure!
Old Jan 13, 2008 | 08:36 PM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320addict &raquo;</TD></TR><TR><TD CLASS="quote">I see it all the time and think it's incredibly unpractical.
I had the front-most corners of the dash notched as to be able to remove and reinstall the dash at any time, looks clean and is functional </TD></TR></TABLE>
Its a race car .The dash doesn't need to come out.Go look at some NHRA cars just about every one is through the dash.
Old Jan 13, 2008 | 08:42 PM
Jon@ForcedFabllc.com's Avatar
i would think that the dash would need to be quite removable in race cars. at least it is with how my car is setup, most of my main wiring and ign stuff is up under there. i have 4 quick turn fasteners that i have holding it in so that i can get it off in seconds.
Old Jan 13, 2008 | 08:51 PM
* B A N N E D *
Default Re: Cages that go THROUGH the dash...how the hell? (Jon@ForcedFabllc.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon@ForcedFabllc.com &raquo;</TD></TR><TR><TD CLASS="quote">i would think that the dash would need to be quite removable in race cars. at least it is with how my car is setup, most of my main wiring and ign stuff is up under there. i have 4 quick turn fasteners that i have holding it in so that i can get it off in seconds. </TD></TR></TABLE>
That car in the pic has a 12 point cage with all the stock interior still in place.
Old Jan 13, 2008 | 09:16 PM
ShawnR's Avatar
Old Jan 14, 2008 | 03:07 AM
Mr. Badwrench
Default Re: Cages that go THROUGH the dash...how the hell? (ShawnR)
i dont see a reason in the futore to remove my dash. i am trying to leave the interior as in tact as i can.
Old Jan 14, 2008 | 06:13 AM
Because **** happens, lets say you fry your interior harness.... its about 120391039 times easier to pull swap them out when the dash is out. You can make a removable dash look really clean, so why not
Old Jan 14, 2008 | 06:33 AM
tony1's Avatar
Default Re: Cages that go THROUGH the dash...how the hell? (BoostedJeff)
I've had my dash out 4 times since the cage has been in...
Old Jan 14, 2008 | 06:48 AM
Mr. Badwrench
i do see your point jeff, and im not arguing. i am dreading the day if it has to come out. i hope it doesnt.
hind sight is always 20/20
Old Jan 14, 2008 | 08:54 AM
redboost10's Avatar
here are some better pics of what i did. and another thing, something i noticed at the lucas oil divisional races, a lot of the superstockers put their brake master cylinder underneath the dash, just to get one less thing out of the engine bay.
Old Jan 14, 2008 | 09:53 AM
Turbo-charged's Avatar
Default Re: Cages that go THROUGH the dash...how the hell? (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">I've had my dash out 4 times since the cage has been in...</TD></TR></TABLE>
you beat me, ive had mine out 3 times
easy removal of dash is top priority!
Old Jan 14, 2008 | 11:36 AM
117's Avatar
117
My dash also comes out with the cage in. It goes through the corners of the dash by the a-pillar. I've had the dash out 2 or 3 times. It doesn't come out easily, but it does come out.
Old Jan 15, 2008 | 12:26 PM
cvp467's Avatar
Default Re: (rota92)
y2kferari
Mar 16, 2007 02:12 PM
cbmprelude
18
Sep 15, 2005 10:04 AM
neilff
Apr 24, 2003 09:46 PM
