compression test question
Old Jan 10, 2008 | 08:34 PM
LStegMATT's Avatar
Default compression test question
is there a way to test compression in a cylinder with the engine out of the car? i have a compression tester, will i get an accurate reading by cranking the engine over by hand a few times or will i lose pressure to fast?
Old Jan 13, 2008 | 07:38 PM
mouab18c1's Avatar
Default Re: compression test question (LStegMATT)
i dont think so....never heard of doing a compression test with the motor out...i just did mine...ran 190 across with a b20b4 bottem end...low comp setup
Old Jan 13, 2008 | 07:48 PM
JDMtegg19's Avatar
Default Re: compression test question (mouab18c1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mouab18c1 &raquo;</TD></TR><TR><TD CLASS="quote">never heard of doing a compression test with the motor out...</TD></TR></TABLE>
me neither
Old Jan 13, 2008 | 08:22 PM
all-mtr-teg's Avatar
Try it, turn the crank over with an impact gun to build pressure.
Old Jan 13, 2008 | 11:11 PM
DOHCgarage919's Avatar
From: Why To Steal My Car, NC, United States Of America
Default Re: compression test question (all-mtr-teg)
wont work, to get accurate readings motor needs to be at WOT
Old Jan 13, 2008 | 11:57 PM
Greasemonkey75's Avatar
You wil not be able to do the compression check however you could do a leak down test. Which in all reality would accomplish the same thing. Kind of a static compression test.....
Old Jan 14, 2008 | 12:31 AM
808DB1's Avatar
the motor needs to be at operating tempature
Old Jan 14, 2008 | 12:37 AM
Default Re: (808DB1)
It would give somewhat of an idea. burnt valves, cracked ring lands, its better than doing nothing. Although at operating temp. would be ideal, it would still work OK..
Old Jan 14, 2008 | 02:11 AM
Blahblah718293's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">Try it, turn the crank over with an impact gun to build pressure.</TD></TR></TABLE>
i wouldnt do that, you may snap the crank bolt.
Old Jan 14, 2008 | 03:40 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 808DB1 &raquo;</TD></TR><TR><TD CLASS="quote">the motor needs to be at operating tempature </TD></TR></TABLE>
Technically yes, but you can still observe cylinder variability when it is cold. OP, have you considered connecting the starter and "jumping" it?
Old Jan 14, 2008 | 05:33 PM
LStegMATT's Avatar
Default Re: (Dogginator)
no i didnt think about that. u mean bolt up my starter, connect it to power and use a bump starter to crank the engine? ill try it. thanks
92vxjdm
Aug 15, 2008 05:05 AM
Got_soy
28
Aug 8, 2005 12:49 PM
snowblind7x
Apr 13, 2005 08:12 PM
F120man
Oct 20, 2002 03:30 PM
