89 civic si *engine dies*???
Old Jan 10, 2008 | 08:21 PM
r.f.b's Avatar
Default 89 civic si *engine dies*???
i drive my car and when i stop at a stop light or just stop at all it'll stall out and die. the check engine light, and bettery light comes on also. i've tried to read the code on my ecu, but it seems to never stop blinking. when is there a pause in the blinking lights so i can tell if it's a long blink or short blink?
just wondering if this engine problem has happened to anyone else so i dont have to search around.
OH YEA ITS A STOCK MOTOR.
Old Jan 11, 2008 | 11:37 AM
kwizical's Avatar
Default Re: 89 civic si *engine dies*??? (r.f.b)
I'm having the same problem. with some hesitation and stuttering too this it what i've done so far. changed plugs, wires and dist cap. new o2 sensor needed it anyway. getting good spark too. then i checked the fuel pump because when it dies it sowly shuts off like it's starving for gas and found that the fuel pump isn't turning on checked it out and think thats my problem if you could check that out and let me know if it's the same thing. and the ecu kept blinking too like yours is doing just unplug the battery connection and it should stop. in my reserch our cars don't have long blinks so just count the short ones let me know what u get.
Old Jan 11, 2008 | 11:57 AM
r.f.b's Avatar
Default Re: 89 civic si *engine dies*??? (kwizical)
yea i got new plugs,dist. cap, rotor, but i didnt get new plug wires that might be it?
like you said though it stutters before it dies like it wants gas, and when it is about to die i try pressing on the gas and theres just no power at all. do you have that problem also?
oh yea but does your check engine light turn on from time to time when your driving? also the battery light?
Old Jan 11, 2008 | 12:36 PM
kwizical's Avatar
yes same problem I just can't figure out what it is i know the fuel pump wont go on anymore tat may be it but i dunno.
Old Jan 11, 2008 | 03:34 PM
wiZCo's Avatar
Stouts 'n' Scotch
Try resetting the ECU by pulling the hazard fuse under the hood for 15 seconds, then replacing it. Run the car until it happens again, then try to pull the code. There should be pauses between multiple codes. A short blink is for 1 and a long blink is for 10. Try to read the code and compare it to the ones listed in the FAQ.
My guess would be an ignition coil, igniter, or main relay. Only one way to tell though...
Try to read the code and report back.
Old Jan 11, 2008 | 07:01 PM
r.f.b's Avatar
Default Re: (wiZCo)
do you know what amperage or volts the ignition coil, igniter, or main relay should be at or just point me in the right direction? thanks for the input
Old Jan 13, 2008 | 10:36 PM
kwizical's Avatar
Default Re: (r.f.b)
I fixed my problem ended up being a bad ground on the fuel pump. it would let me start up and idle fine but once i started driving the vibrations shook it and would kill the fuel pump thats why i was stalling out. check it out althought you'll have to drop the tank to do a continuity test on the wires.. hope that helps good luck
Old Jan 21, 2008 | 02:29 AM
kwizical's Avatar
Default Re: (kwizical)
did u ever figure it out?
waterboyRob
Feb 17, 2014 12:06 PM
Ice-Nine
Jun 28, 2008 07:14 AM
r1mshady
Jun 27, 2006 05:39 PM
EK45VTi
Mar 1, 2004 02:50 AM
AsiAnVenOm
Feb 23, 2003 11:32 PM
