Neuspeed race springs on ek with 205/50/15, will I rub??
Like the title says.... Im looking to get neuspeed race springs on my ek sedan. I have LS meshies with 205/50/15 falken tires. Will I rub in the front?? Anyone else running these springs please give me some imput wheather you like them or not. thanks in advance
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turnsignalandy »</TD></TR><TR><TD CLASS="quote">what if the plastic guards inside the fenderwells are to be removed? Ir will I rub against the fender itself?</TD></TR></TABLE>
you need those plastic guards bro...rent a fender roller and do it yourself. If not have a shop do it. Or in my case i took off the clips that hold the outter plastic guard and that solved the problem for me. I"m running 205/50/15's 2.5inchs all around with no rubbing issues.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mormonboy »</TD></TR><TR><TD CLASS="quote">lolz. no you wont rub. their just springs. </TD></TR></TABLE>
as for this guy ^ dont listen to him...you'll def rub with that kind of drop. Its not going to be too much but it will rub.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmoua »</TD></TR><TR><TD CLASS="quote">I"m running 205/50/15's 2.5inchs all around with no rubbing issues.</TD></TR></TABLE>
What wheel width and offset? '96-00 Civic?
I had these springs on my car on the stock struts
not my choice but i was tucking and hardly rubbed even at full lock. That was the only time it would even touch. Any one know what the spring rates are for the neuspeed race springs?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">
What wheel width and offset? '96-00 Civic?</TD></TR></TABLE>
true didn't realize that....but im running OEM EM1 rims which i believe is 15x6 with a offset 45. Im slammed roughly around 2.5inchs all around. Before i rolled my fenders i'd rub making u-turns and taking wide turns. Yes its a 99 civic coupe.
like everyone said, i really doubt you'll rub unless your running a super low offset like in mycase (205/50/15 15x7 +20 offset enkeis).
so unless you run a super low offset with wide rims, some race springs wont rub anything.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turnsignalandy »</TD></TR><TR><TD CLASS="quote">thanks for all the imput. Now can anyone direct me towards instructions to install illuminas on a 96-00 civic????</TD></TR></TABLE>
https://honda-tech.com/zerothread/1998336
FLYNLOW
Suspension & Brakes
Jan 4, 2007 02:47 PM
Civiclx
13
Jan 29, 2004 10:56 AM
