b1c block ls crank need help????
ok heres my problem i have a good gsr block clean but it spun a bearing took it all apart an it looks really bad its gone lol
in the mean time i lost the bridge cap that holds the main bearins in place
i was thinking of using my ls crank rods (balanced) on the gsr an was wondering if i could just use the ls main bearing caps on the gsr would it still work???
please need some help
they'll fit BUT
you wont be able to use the girdle, and you will have to use the LS windage tray, oil pickup and oil pan....
and like boostedcivicsir said, you will need an align hone on the mains.
good luck
good luck
