axle help again
95 civic coupe w/h22 swap
hi i posted up a couple days ago axles were knocking and shaking was told too raise my car up 2-3 fingers width did that. it still shakes at high speeds and when im getting up too speed and when i turn it clinks. I think i need new axles my drivers side boot is torn but it sounds like its coming from passenger side.
If i have too buy new axles do i have too get custom hybrid ones or can i just order stock h22 axles ?? Thanks i need all the advice i can get
The clink while turning noise, deff. sounds like a cv joint and since your boot is torn there may not be much grease left in it. Time for a new axle. Im not sure on which one to use, im sure someone has asked before. Try a search.
yeah deff. replace that axle asap i had my passenger side axle go out on the freeway i was drivn them next thing i know my cars doin a right lane change by its self
it just pulleed the wheel to the right all bad......and if you do change it you might as well change both and where to buy them i got mine from kragen auto parts all good so far and they got a lifetime warrantie
penney
May 30, 2005 06:58 PM
mingbling96
Mar 13, 2005 08:14 AM
NstyGrnHatch
10
Feb 15, 2005 11:35 AM
