HELP ASAP! tourqe specs for d15b7
Old Jan 10, 2008 | 02:37 PM
dertymatt's Avatar
Default HELP ASAP! tourqe specs for d15b7
i blew the headgasket so i took everything apart got the gaskets, got the head decked so its ready to be put back on but i dont know the tourqe specs for the head and the manifolds. also i need to know what the tightining pattern is for the head bolts.
if anyone can tell me what it is or give me a link it would be much appreciated!
thanks in advance!!!
Old Jan 10, 2008 | 02:52 PM
boostedNOTHARDLY's Avatar
10 4 2 6 8
Torque in 3 steps. (Or thats how I did it to be efficient)
Tighten all 10 bolts in order to 14 ft lb.
Tighten all 10 bolts in order again to 36 ft lb.
Tighten all 10 bolts in order again to 49 ft lb.
Go back and re-torque bolts #1 and #2 to 49 ft lb.
Old Jan 10, 2008 | 02:55 PM
dertymatt's Avatar
Default Re: (boostedNOTHARDLY)
is #1 starting from top left?
Old Jan 10, 2008 | 02:56 PM
no, #1 bolt is the center top bolt. just like i showed you.
Old Jan 10, 2008 | 02:57 PM
http://www.hondaworkshop.com/misc/97-047TSB.jpg
Old Jan 10, 2008 | 02:59 PM
dertymatt's Avatar
ohh i see. yo thanks alot bro!!!!
Old Jan 10, 2008 | 03:02 PM
np, helped me alot whenever i had to do that same job
Old Jan 11, 2008 | 11:46 AM
dertymatt's Avatar
what should the manifolds be tourqed to? also the cam gear? also from the header to exhaust pipe? those bolts were hard as hell to get off so im not sure if they need to be tourqed to?
shytdoode
25
Jan 20, 2010 09:19 AM
GsrIntegra789
Sep 28, 2006 07:26 AM
orangeracer
May 23, 2006 03:32 PM
tuan...
Nov 20, 2004 01:37 PM
Four Door LS VTEC
Feb 13, 2003 05:13 PM
