is there a DYI on how to convert a 88' OBD0 to OBD1 GSR
right i have the OBD0 OBD1 hrness.
i'm dropping a 99GSR into a 88' si rex.
thanks for your input.
The schematic for OBD-0 to 0BD-1 is a write-up I did which is currently posted in the FAQ, be advised that I omitted items such as a knock sensor as the ECU that was used in my example (P06 Modified) did not need one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dead CIVIC »</TD></TR><TR><TD CLASS="quote">right i have the OBD0 OBD1 hrness.
thanks for your input.</TD></TR></TABLE>
check the FAQ, IIRC there are a couple threads under the "engine and swap" section.
https://honda-tech.com/zerothread/1508680
