Any way to make obd0 dizzy work as obd1
Re: Any way to make obd0 dizzy work as obd1 (NOSED_CRX_VTEC)
Not sure if this affects it, but the number of "Clicks" a certain distributor has will not allow it to work outside of its year. I tried wiring a OBD1 dist. into a obd0, no luck
Re: Any way to make obd0 dizzy work as obd1 (JDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg »</TD></TR><TR><TD CLASS="quote">you cant swap the sensors, obd1 has 24 tooth sensor, obd0 has 16 teeth.</TD></TR></TABLE>
The it's only the wheel inside the dizzy that has 24 teath cant that be swaped
Correct, which means the CYL, and CYP signals are all off.
Doesn't work.
OBD1 and OBD2 are the same tho.
Doesn't work.
VegasInvasion
07-01-2010 10:49 AM
ludesrv
05-12-2007 08:58 PM
Driven
08-25-2004 07:02 PM
EFing8
01-29-2003 08:40 AM
