this cant be normal
Old Jan 9, 2008 | 08:35 PM
MMBmomoney's Avatar
Default this cant be normal
it always seems like i have problems.. maybe thats y the car isnt finished yet..
okay after changing two coolant line
1. bypass0
2. i bealive the heater... runs from the block under distributor (b16) to the firewall
then the car wouldnt start and the next morning i noticed antifreeze on the drive floor on the othside corner? this **** cant be norma;.
any suggestions.. i already examined the motor, the crank and camshaft spin.
Old Jan 10, 2008 | 09:12 PM
db1_jdm's Avatar
Default Re: this cant be normal (MMBmomoney)
and your problem is........
Old Jan 11, 2008 | 08:03 AM
MMBmomoney's Avatar
Default Re: this cant be normal (db1_jdm)
the car wont start and their is coolant on the drive side floor under the pedals.... i checked the started and it spins hard. so its not that.
Old Jan 11, 2008 | 08:07 AM
BryanM.'s Avatar
Resident Gearhead
Sounds like your heater core is leaking, but that would not cause it to not run...
Old Jan 11, 2008 | 08:31 AM
MMBmomoney's Avatar
Default Re: this cant be normal (mcvtec)
a buddy told me that.. he also told me a need to take my dash off to fix it... do u know anything bout replacing and price on that piece
Old Jan 11, 2008 | 12:53 PM
BryanM.'s Avatar
Resident Gearhead
Helms/Haynes manual for replacement info.
I didn't shop around but I did find this:
AutoPartsWarehouse.com - part# RR398325 - replacement heater core $105.91
There may be a beter deal out there though...make sure it's faulty before replacing. GL
bboysake
Feb 20, 2010 06:35 PM
dalek
Aug 22, 2008 03:03 AM
LowBuckRacin
10
Nov 2, 2003 03:43 PM
Fatty_1775
Jul 17, 2003 11:10 PM
Doodoo
May 27, 2003 01:37 PM
