Auto ECU and Manual ECU diff? Quick q?
Old Jan 9, 2008 | 08:19 PM
Fook_me_honda's Avatar
Default Auto ECU and Manual ECU diff? Quick q?
I was wondering if it was possible to run a manual ECU on an auto. I found a deal on a car i want to buy but the ECU is missing and earlier today my brother took a friends EX ecu out there and said it wouldn't start it. Problem is his is a manual and the car is an auto.
Also is it possible i could limp the car back home on a 1996 GSR ecu?
Old Jan 9, 2008 | 08:20 PM
93egSLEEPER's Avatar
Default Re: Auto ECU and Manual ECU diff? Quick q? (Fook_me_honda)
nooot possible bro.
Old Jan 9, 2008 | 09:07 PM
ejoner's Avatar
Default Re: Auto ECU and Manual ECU diff? Quick q? (93egSLEEPER)
You can drive the car on a manual ecu you WILL have a cel light on, I don't know if its bad for the transmission, just put it home slowly with a manual ecu.
Old Jan 9, 2008 | 09:19 PM
mini-meEj1's Avatar
Default Re: Auto ECU and Manual ECU diff? Quick q? (ejoner)
i believe that the Gsr ecu will flood the engine out. The only diff. between an auto and a manuel ecu is the resestior location.
Old Jan 9, 2008 | 09:24 PM
ejoner's Avatar
Default Re: Auto ECU and Manual ECU diff? Quick q? (mini-meEj1)
Yes but the resistor controls something in the automatic transmission.
Old Jan 9, 2008 | 09:35 PM
mini-meEj1's Avatar
https://honda-tech.com/zerothread?id=1275452
op with a little soldering skills this conversion can be done
Old Jan 9, 2008 | 11:58 PM
its ok. i just wanted to limp the car home until i had something more permenant. but the guy found an ecu for the car so its all good now. thanks guys, ill keep the info for future reference.
akouznet
May 24, 2009 06:50 PM
ballified
Oct 13, 2007 02:34 PM
ringgold
Sep 29, 2004 12:02 PM
integra_gsr98
Jun 10, 2003 08:42 PM
ek_will
May 4, 2003 07:24 PM
