CEL help
Old Jan 9, 2008 | 03:13 PM
afstvx's Avatar
Default CEL help
hi there i have a 95 civic vx i had a b16 in my car till i broke the tranny so in the mean time i hvae swapped over a d16z6 motor but now for some reason when i drivng and i down shift to slow down my CEL comes on its only when im decelerating like on the freeway in 5th gear if i let off the gas to just slow down alittle the CEL comes on. but as soon as i turn my car off then back on the light goes away. the only thing i can think of is i took the charcoal canister out and maybe that has somthing to do with it. this never happened with my b16. but i also ahd the charcoal canister in when i had the b16 in only when i just swapped out the motors i took to canister out cause it was ugly. any help is much appreciated.
Old Jan 9, 2008 | 03:32 PM
pdotjones's Avatar
Default Re: CEL help (afstvx)
what code is it?
https://honda-tech.com/zerothread?id=682412
Old Jan 9, 2008 | 04:58 PM
afstvx's Avatar
Default Re: CEL help (pdotjones)
i havent checked the code becasue everytime i turn the car off to check it when i turn it back on the CEL is not on. and i was not sure if jumping the plug while the car was on is ok or will it short somthing out. becasue i know that the directions say to turn the car off then jump the plug the turn the car back to the on positon.
Old Jan 9, 2008 | 05:25 PM
z6hatchboy's Avatar
I had a similar problem, and was told, its a soft code. Leave the car on and check it. My problem was the tps sensor.
Old Jan 9, 2008 | 06:03 PM
afstvx's Avatar
Default Re: CEL help (z6hatchboy)
cool thanks i will try that out.... i wont hurt the car right???
thegame7
16
Jun 21, 2013 06:16 AM
slowesteg
May 11, 2012 11:07 PM
moomakudafi
Feb 27, 2007 12:58 AM
vtec_r
Oct 19, 2003 11:17 AM
