INTEGRA AXLES??
Old Jan 9, 2008 | 02:01 PM
lowtegsr's Avatar
Default INTEGRA AXLES??
OK my 94 integra gs-r is clicking real bad when i make a right turn, which everyone is telling me it's my passenger side front axle. ok i want to throw a turbo on in the future and i was wandering if i should put a certain axle on when i replace them so i don't destroy them, what all different axles are compatible with my car, and r the type r axles any better to replace mine? any information is appreciated, thanks!!!
Old Jan 9, 2008 | 03:00 PM
Byaaah!'s Avatar
Jet Life Til' The Next Life
Default Re: INTEGRA AXLES?? (lowtegsr)
Unless you have a high and I mean pretty high horsepower Integra, thats when you should but I would just stick with OEM axles, even if you are boosted...
Old Jan 9, 2008 | 10:31 PM
MrDomino's Avatar
https://honda-tech.com/zerothread?id=2008493
check that thread out
main consensus from everyone was to stick with stock axles and replace them as they break- better to break a cheap axle than an expensive tranny
Old Jan 9, 2008 | 11:07 PM
Shakey021's Avatar
yeah i would rather replace axels then trannys anyday !!!
Old Jan 9, 2008 | 11:39 PM
xRacerX81's Avatar
autozone 60 bucks after core... life time warranty,best way to go
Old Jan 10, 2008 | 02:25 AM
sg's Avatar
sg
Default Re: (xRacerX81)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xRacerX81 &raquo;</TD></TR><TR><TD CLASS="quote">autozone 60 bucks after core... life time warranty,best way to go</TD></TR></TABLE>
well worth it
Old Jan 10, 2008 | 10:49 AM
lowtegsr's Avatar
ok so if i'm putting new front axles on, r there any other little parts i should buy or replace while doin this?
Old Jan 10, 2008 | 11:36 AM
weavertime1's Avatar
Default Re: (lowtegsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lowtegsr &raquo;</TD></TR><TR><TD CLASS="quote">ok so if i'm putting new front axles on, r there any other little parts i should buy or replace while doin this?</TD></TR></TABLE>
You might also want to replace the axle seals which are located in the transmission where the axle slides in on the passenger side and where the intermediate shaft slides in on the driver side. It may not be necessary, but if you notice oil leaking from your transmission from these areas it might be worth replacing them. Good luck with your new axle install!
Old Jan 10, 2008 | 03:08 PM
Options's Avatar
All Secrets Known
W3rd....I just got my driver side axle from there. $60 + lifetime warranty =
Old Jan 10, 2008 | 03:45 PM
Schister66's Avatar
Man U FTW
That's what i use and this spring, they'll see around 400whp...if they break, i'll just return them. Having said that, i dont forsee any problems.
Gonzob16
Nov 23, 2006 08:19 AM
93 ls
Aug 1, 2006 03:30 PM
prostreetonline
Jul 7, 2006 04:13 PM
im_poor
Mar 7, 2003 06:55 AM
fred92htch
Jul 10, 2002 02:07 PM
