My speedo is failing
Old Jan 9, 2008 | 01:20 PM
ghettoSi's Avatar
she's cheating on you
Default My speedo is failing
So my speedo went out a couple months ago and I just got around to buying a new speed sensor a few weeks ago. I put it in and it worked fine for a week or two then went out again. I looked at the plug that plugs into the sensor and it was all coroded so I cleaned it out REALLY good, still doesn't work. Could it be my cluster? I really don't have any other ideas. Any help is appreciated
Old Jan 9, 2008 | 01:24 PM
philosofy1's Avatar
Default Re: My speedo is failing (ghettoSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ghettoSi &raquo;</TD></TR><TR><TD CLASS="quote">So my speedo went out a couple months ago and I just got around to buying a new speed sensor a few weeks ago. I put it in and it worked fine for a week or two then went out again. I looked at the plug that plugs into the sensor and it was all coroded so I cleaned it out REALLY good, still doesn't work. Could it be my cluster? I really don't have any other ideas. Any help is appreciated </TD></TR></TABLE>
could be, if you know someone, make it alittle cheaper on yourself. see if they would allow you to swap out clusters. if there cluster works fine then you know yours is bad.
Old Jan 9, 2008 | 01:25 PM
ghettoSi's Avatar
Default Re: My speedo is failing (philosofy1)
Alright good idea I will see if one of my buddies will let me try one of there clusters. Thanks
ryrex02
Dec 7, 2010 05:53 PM
EGed up from the seat up
34
Sep 16, 2008 06:37 AM
hip_hop_s0ulchild
Mar 1, 2007 03:41 PM
snackpack
Dec 18, 2006 02:39 PM
