integra ls engine into a 89 civic dx hb
Old Jan 9, 2008 | 10:25 AM
kryptproductions's Avatar
Default integra ls engine into a 89 civic dx hb
would it be a good swap???what all would i have to do??? please help
Old Jan 9, 2008 | 10:28 AM
wiZCo's Avatar
Stouts 'n' Scotch
I hate to be cliche, but read the FAQ.
calling a swap "good" means different things to different people. You have to consider your budget, goals and mechanical abilites.
In terms of parts needed and any wiring changes that will have to be made, consult the FAQ.
Old Jan 9, 2008 | 10:30 AM
Default Re: (wiZCo)
would it be quicker then a d16a6 is what im asking. and i have 1500 to work with... i found a 1.8l ls engine on ebay for 499.00 with 101k on it and i called a salvage yard and can get a good transmission for it for 200.00
Old Jan 9, 2008 | 10:33 AM
wiZCo's Avatar
Stouts 'n' Scotch
It's faster than a D16A6, but not by very much. $1500 should get the swap done for you if you source your parts for cheap. Don't forget you'll need axles, mounts, shift linkage, an ECU and the parts for the MPFI conversion. You may also need a new radiator. Not to mention the tuneup parts you'll need. I've found that a properly done B-series swap usually runs around $2K.
If you're not planning on building internals or going turbo, I'd actually suggest a DOHC ZC instead. It'll cost much less than the LS and give similar results.
Old Jan 9, 2008 | 07:52 PM
Default Re: (wiZCo)
ive having a hard time finding a d16a6 in michigan and indiana, i wanna turbo whatever engine i deside to do, only a small turbo tho like 5-6psi know what im sayin nuttin huge or anything just somthing pretty quick. but now when i get more money to work with on the other hand i wanna build a track car or somthing.anyway yeah ive been looking on hmotorsonline quite a bit but i dont know how much shipping and all that is. cuz i first wanted the d15b SOHC VTEC seems like a badass engine. i think the price was 499.00 with everything. yea ill check into the ZC. if you know anything like the shipping cost on hmotorsonline you should lemme know! thx
Old Jan 9, 2008 | 08:00 PM
black0hatch's Avatar
Default Re: (kryptproductions)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote">It's faster than a D16A6, but not by very much. </TD></TR></TABLE>
are you serious? a ls is a good swap cause its easy and cheap. your better off finding a motor localy maybe out of a wrecked teg. my first swap was a ls motor and after everything i spent maybe a 1000 thats an over estimate. and ls motors are great to boost plus it has lots of tourqe stock. it will feel much faster then a single cam any day.
Old Jan 10, 2008 | 09:36 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (black0hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black0hatch &raquo;</TD></TR><TR><TD CLASS="quote">
it will feel much faster then a single cam any day.</TD></TR></TABLE>
Feel faster, but I don't really consider a few tenths of a second off the 1/4 mi time to be a significant jump. To each his own.
My point was that with his budget, he could do a D16A6, D15B VTEC or DOHC ZC swap and still haver some $$$ left over for a small boost setup. That would be significantly faster than a LS swap.
Old Jan 10, 2008 | 03:51 PM
Default Re: (wiZCo)
thx for your help ill keep you posted i finaly found a a6 and tranny so thx
Old Jan 10, 2008 | 04:37 PM
ef9itb's Avatar
Default Re: integra ls engine into a 89 civic dx hb (kryptproductions)
if ur going turbo i'd rather put an ls engine jus because it will have better potential than an a6 engine. but if u wanna just have fun boost the sohc
Old Jan 10, 2008 | 07:46 PM
Default Re: integra ls engine into a 89 civic dx hb (ef9itb)
its my first swap and everything thats why im doing the a6 but l8ter on when i know alot more and have hands on exp. then ima do somthing like a ls swap know what i mean. this is my first project car.
MatthewJ
25
Feb 18, 2010 10:46 AM
S A D A N
Mar 24, 2009 08:27 AM
ximportman
Jan 24, 2009 09:39 PM
jdmnerd32
Dec 15, 2008 12:18 PM
turbo_d
10
Jul 6, 2008 03:25 PM
