D16 build up
d16z6? if thats what it is and it was me id get wescco 12:1 high compression pistons and all the works, but befor that id go with a I/H/E set up. maybe a new throttle body, short shift....probably be cheaper to just boost it on low boost and have it tuned by someone who knows what they are doing. just read around and u will find plenty of ideas
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tensecpass »</TD></TR><TR><TD CLASS="quote">d16z6? if thats what it is and it was me id get wescco 12:1 high compression pistons and all the works, but befor that id go with a I/H/E set up. maybe a new throttle body, short shift....probably be cheaper to just boost it on low boost and have it tuned by someone who knows what they are doing. just read around and u will find plenty of ideas</TD></TR></TABLE>
Quoted for hilarity.
Depends on your goals. How built do you want to go? How much power/what times would you like to try to run? Too many variables to tell you a straight answer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondakid4dr »</TD></TR><TR><TD CLASS="quote">can someone give me a list of parts that i consist of a fully buit d16</TD></TR></TABLE>
and your budget. get some higher compression pistons, new rings. new timing belt and water pump. all the gaskets..head studs..new camshaft..valve..vavle springs and retainers.. intake manifold and throttle body.injectors...ect...
its all depends on how much u want to spend and how many hp u are looking for to gain. and your future plan wit the engine.such as turbo it or do the swap in the future.
Generic question #98793489475497975397439439
Budget?
Horsepower goals?
Mechanical experience?
What kind of car?
What goals performance wise?
Street car? Road race? Drag race?
Budget?
Horsepower goals?
What kind of car?
jarven93
14
Dec 12, 2006 05:33 PM
one slow coupe
Mar 19, 2006 05:52 PM
Do some research
