I NEED HELP PLZ!!!
Old Jan 8, 2008 | 07:15 PM
hondakid4dr's Avatar
Default I NEED HELP PLZ!!!
MY IDLE is really low like under 1 and the car sputters...the car tends to cut off at stop lights...and when im am drivin its hiccuping and the power isnt there... ive changed spark plug, wires,altenato, fuel pump any idead on what it could be.
Old Jan 8, 2008 | 07:28 PM
ek-g6's Avatar
Default Re: I NEED HELP PLZ!!! (hondakid4dr)
is the engine check light on?
Old Jan 8, 2008 | 07:35 PM
Default Re: I NEED HELP PLZ!!! (ek-g6)
i have no engine check light
Old Jan 8, 2008 | 07:42 PM
zero708970's Avatar
Clean or change your idle control valve (iacv) if you don't know where it is do a quick search.
Old Jan 8, 2008 | 07:44 PM
laocivic's Avatar
Default Re: I NEED HELP PLZ!!! (zero708970)
clean ur fitv or w/e it is...that worked on my car
Old Jan 8, 2008 | 07:47 PM
Default Re: I NEED HELP PLZ!!! (laocivic)
can i clean it o do i take it somewhere
Old Jan 8, 2008 | 07:49 PM
ShaggyZ6's Avatar
you can clean it with carb cleaner
Dead CIVIC's Avatar
Veteran: Army
you can do it yourself it is easy.
Old Jan 8, 2008 | 07:56 PM
Default Re: I NEED HELP PLZ!!! (Dead CIVIC)
do u thinnk my timing belt can cause this problem also....if its going
Old Jan 8, 2008 | 08:20 PM
zero708970's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondakid4dr &raquo;</TD></TR><TR><TD CLASS="quote">do u thinnk my timing belt can cause this problem also....if its going</TD></TR></TABLE>
No.
EG-SIXV-TEC
Nov 6, 2009 12:20 PM
donovan772
11
Sep 9, 2009 06:09 PM
nickhans
Sep 19, 2005 10:04 AM
Supa_Slow_Civic
15
Apr 30, 2005 05:07 PM
stoopid_monkey
Apr 26, 2005 11:22 PM
