Removing ABS
I did some searching and found some information but I was unable to find an in depth explanation of this process. I own a 2001 LS and I decided that i want to remove ABS. I found out reading that unlike most other g3s, like the 94-97s that the 98 and newer ones you are able to use the RS Master Cylinder with the factory Brake Booster.
My question might seam dumb, maybe I am missing something really simple but how do these 2 Lines off the Master Cylinder get distributed to 4 lines for each Caliper?
And also where is the best place to find an adjustable proportioning valve?
Sivic90
Nov 14, 2008 04:23 AM
