Removing ABS
Old Jan 8, 2008 | 07:11 PM
rdssk8rcs1's Avatar
Default Removing ABS
I did some searching and found some information but I was unable to find an in depth explanation of this process. I own a 2001 LS and I decided that i want to remove ABS. I found out reading that unlike most other g3s, like the 94-97s that the 98 and newer ones you are able to use the RS Master Cylinder with the factory Brake Booster.
My question might seam dumb, maybe I am missing something really simple but how do these 2 Lines off the Master Cylinder get distributed to 4 lines for each Caliper?
And also where is the best place to find an adjustable proportioning valve?
Old Jan 8, 2008 | 07:24 PM
3rdgenintegra48's Avatar
Default Re: Removing ABS (rdssk8rcs1)
throw me you abs unit if you dont want it
Old Jan 8, 2008 | 07:36 PM
rdssk8rcs1's Avatar
Default Re: Removing ABS (3rdgenintegra48)
I will be selling it
Old Jan 8, 2008 | 07:52 PM
PrinceAli132's Avatar
ABS Removal
Ali
dustinbs144
Nov 10, 2010 05:27 PM
Ohio
Sep 29, 2010 11:30 AM
dc4teg95
Feb 23, 2009 04:15 AM
Sivic90
Nov 14, 2008 04:23 AM
