need ls help with srp pistons
Old Jan 8, 2008 | 04:55 PM
krazyturbo1's Avatar
Default need ls help with srp pistons
i have a b18a1 block with srp pistons i just tore the motor down and everything looked great the only question i have is there is a noticable gab between the piston and wall as far as i know the block was never bored out is this normal ??? the pistons due move in the sleeve should i be worried>>>motor never smoked ran great on boost any input would be great thanks
Old Jan 8, 2008 | 05:46 PM
DAneronimo's Avatar
put up a picture. there is always a noticable gap at the top
the pistons are actually tapered. they are larger at the bottom than they are at the top.
thats why the piston to wall clearance is supposed to be measured at a certain distance (cant remember what) from the bottom of the piston.
in a nutshell....check your piston to wall clearance. if its in spec; you're good
Old Jan 8, 2008 | 06:03 PM
Default Re: (DAneronimo)
does anyone know what the piston to wall clearences are on a b18a1 i will post pics tomm
Old Jan 8, 2008 | 07:22 PM
DAneronimo's Avatar
you need to go by the piston manufacturers specs...not honda specs
this information should have come with the pistons; if not just give srp a call. im sure they will tell you
krazyturbo1
Jan 8, 2008 05:28 PM
DC4 Rasta
Jan 5, 2007 06:44 PM
hookups214
Jan 27, 2006 09:07 AM
95c1v1cs1
Jul 28, 2004 09:44 AM
5thgencivic
Nov 29, 2003 03:26 PM
