Wiseco Piston Ring Problem...
Old Jan 8, 2008 | 01:34 PM
pornstar4777's Avatar
Default Wiseco Piston Ring Problem...
I ordered new rings and they sent the following...the package says 3189XC, which are 81 mm and when I look them up it's a Kawasaki/Yamaha application. According to the Wiseco website, the K566M81 pistons use 8100XX piston rings. Are they the same/correct?
Old Jan 8, 2008 | 02:18 PM
DonF's Avatar
Default Re: Wiseco Piston Ring Problem... (pornstar4777)
What is the differance between 3.189 inches and 81mm? This should answer your question.
Old Jan 8, 2008 | 02:45 PM
Rocket's Avatar
Default Re: Wiseco Piston Ring Problem... (DonF)
The XX set has a higher tension oil ring than the XC set.
Old Jan 8, 2008 | 03:05 PM
Default Re: Wiseco Piston Ring Problem... (Master of the Universe)
so that means I have to return them!
Old Jan 8, 2008 | 03:15 PM
DonF's Avatar
Depends on the tension you were looking for. Did you want 7 or 9 lbs,? How many mm is 3.189 inches?
Old Jan 8, 2008 | 03:28 PM
4g hatch's Avatar
3.189=81mm
3.199=81.25mm thats as far as honda recomends on factory sleeves so i dont know any more
you just need to figure your tension goals[proceed to engine builder for advice]
Old Jan 8, 2008 | 03:29 PM
4g hatch's Avatar
Default Re: Wiseco Piston Ring Problem... (4g hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">Depends on the tension you were looking for. Did you want 7 or 9 lbs,? How many mm is 3.189 inches?</TD></TR></TABLE>
sorry i didnt realize i ruined it
Old Jan 9, 2008 | 09:36 AM
what's the difference in tension?
Old Jan 9, 2008 | 09:37 AM
mar778c's Avatar
Community Builder
Community Influencer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pornstar4777 &raquo;</TD></TR><TR><TD CLASS="quote">what's the difference in tension?</TD></TR></TABLE>
2 lbs.
Really, no difference.
Old Jan 10, 2008 | 04:13 AM
Default Re: Wiseco Piston Ring Problem... (mar778c)
so use them and I'll be fine? No difference worth mentioning?
Old Jan 10, 2008 | 04:16 AM
mar778c's Avatar
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pornstar4777 &raquo;</TD></TR><TR><TD CLASS="quote">so use them and I'll be fine? No difference worth mentioning?</TD></TR></TABLE>
Yes
DC2TT
Jan 9, 2006 07:47 PM
DC2TT
Nov 11, 2005 10:44 AM
non-VTEC
Oct 26, 2002 08:15 AM
Islander
Oct 11, 2002 02:45 AM
