head unit does not work after correctly hooking up...checked fuses
Old Jan 8, 2008 | 11:16 AM
lmike6453's Avatar
Default head unit does not work after correctly hooking up...checked fuses
ok, so i just did a dash replacement and transfered the dash harness os i would have the same setup...afterwards, i completely re-did the headunit wiring because it was not working and refered to a diagram from team-integra.net to make sure...everything is hooked up correctly and the cigarette lighter works, as well as the clock.....what could be the problem? i even tried to ground the ground wire elsewhere....
Old Jan 8, 2008 | 11:20 AM
St Jimmy's Avatar
* B A N N E D *
Default Re: head unit does not work after correctly hooking up...checked fuses (lmike6453)
A bad head unit?
Old Jan 8, 2008 | 11:28 AM
imsickofrice's Avatar
Default Re: head unit does not work after correctly hooking up...checked fuses (St Jimmy)
bust out a test light and test your constant power 12+ and accessory wire..
Old Jan 14, 2008 | 06:05 PM
sDc5's Avatar
nice i have the same problem. i took off the dash and now the head unit isn't work
i rewired the setup and still the head unit doesn't power but the subs and amp turns on. let me know if you found a solution so will i
Old Jan 15, 2008 | 07:26 AM
all-mtr-teg's Avatar
Check the backup fuse under the hood its a 7.5 amp I believe
itsrooster
Honda Civic (2001 - 2005)
Jan 7, 2013 03:49 PM
EuroEGHB
Audio / Security / Video
Jan 13, 2010 09:26 PM
Chitown Si
Jun 26, 2007 03:39 PM
hob4G
Jul 1, 2004 02:55 PM
RockDawg_GSR
Oct 16, 2003 04:37 AM
