B20vtec N/A, S2S2 or S2 pro1's?!?!
Old Jan 8, 2008 | 09:04 AM
SpoonEk253's Avatar
Default B20vtec N/A, S2S2 or S2 pro1's?!?!
Im currently running a b20vtec N/A w/ around 11:2 - 11:3:1 compression. I recently just got it tuned on the set up below, but maxed out my prelude 290cc injectors at 6k. I just bought some RC 550cc injectors and need help on deciding if skunk2 stage2 would suite me better or Will Skunk2 pro1's be over kill for my compression. i also purchased skunk2 proseries dual valve springs and ti retainers!
Gsr head mild port and polished
stock valve train (Changing to skunk2 proseries)
skunk2 stage 1 cams (skunk2 stage2 or Pro1's?!?!)
skunk2 cam gears
skunk2 proseries mani
BDL 70mm Throttle body port matched
AEM fuel rail
290cc prelude injectors (Changing to RC 550cc)
custom 3'' intake piping w/ blox funnel
hondata intake mani gasket
Hytech Replica headers
GE vtec kit
b20b block
JE 10:5:1 pistons
JE Piston rings
ARP rod bolts
ACL STD main,thrust, rod bearings
Gsr water pump
Gsr oil pump
Gsr pick up
unorthodox racing pulley
7.5lbs fidanza flywheel
stage 1 clutch
stage 1 pressure plate
Endyn breather kit
T1R Full exhaust system
Old Jan 8, 2008 | 09:49 AM
racebucket_eg's Avatar
Default Re: B20vtec N/A, S2S2 or S2 pro1's?!?! (SpoonEk253)
Here is a good link with some info.
https://honda-tech.com/zerothread/2130357
Old Jan 8, 2008 | 10:11 AM
D-Rob's Avatar
Default Re: B20vtec N/A, S2S2 or S2 pro1's?!?! (racebucket_eg)
I would consider the Pro2+'s, actually.
They work great on my 11.7:1 LSVTEC, and I expect they would work just as well in your two-liter engine.
- Derek
Old Jan 8, 2008 | 12:33 PM
SpoonEk253's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racebucket_eg &raquo;</TD></TR><TR><TD CLASS="quote">Here is a good link with some info.
yea i've read the how 5pgs on it but doesnt really help on what kinda compression is ideal for pro1's...i know i can run s2s2 no prob but if i can run pro1's w/ my compression imma go for it. thats the answer im looking for?
Old Jan 8, 2008 | 12:49 PM
IntegraType-R's Avatar
same cam really can't go wrong either way.
Old Jan 8, 2008 | 12:50 PM
Mhollaek9's Avatar
i dont think there is enuff compression for pro2s stick with the stage 2
Old Jan 8, 2008 | 02:03 PM
SpoonEk253's Avatar
Default Re: (Mhollaek9)
enough compression for pro1's tho?
Old Jan 8, 2008 | 02:48 PM
2fastGSR's Avatar
King of the One Liners
Default Re: (SpoonEk253)
pro 1 or 2 should be fine imo
Old Jan 8, 2008 | 02:49 PM
D-Rob's Avatar
Default Re: (2fastGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mhollaek9 &raquo;</TD></TR><TR><TD CLASS="quote">i dont think there is enuff compression for pro2s stick with the stage 2</TD></TR></TABLE>
Did you read that on Honda-Tech?
- Derek
Old Jan 8, 2008 | 02:53 PM
SpoonEk253's Avatar
Default Re: (D-Rob)
im leaning more to pro'1 but no one has deals on them....i found some skunk2 stage2's for $350shipped
Old Jan 8, 2008 | 07:02 PM
SpoonEk253's Avatar
Old Jan 8, 2008 | 08:53 PM
1 2 NV's Avatar
any one of those will do but id run pro 2s if i were you. check your retainer to valve seal clearance and check your V2V. you should need to run your exaust cam 4 degrees advanced to get minimum V2V clearance.
Old Jan 8, 2008 | 09:52 PM
SpoonEk253's Avatar
Default Re: B20vtec N/A, S2S2 or S2 pro1's?!?! (1 2 NV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 2 NV &raquo;</TD></TR><TR><TD CLASS="quote">any one of those will do but id run pro 2s if i were you. check your retainer to valve seal clearance and check your V2V. you should need to run your exaust cam 4 degrees advanced to get minimum V2V clearance.</TD></TR></TABLE>
yea i plan on claying the motor for clearance if i go w/ pro1's
SpoonEk253's Avatar
pro2's just seem like it'll over cam my motor since the motor is only around 11:3:1
Old Jan 9, 2008 | 02:56 PM
Rollo Lawson's Avatar
https://honda-tech.com/zerothread?id=1338293
Old Jan 9, 2008 | 04:23 PM
Default Re: (Rollo Lawson)
From the link above, the stage 2's made around the same amount of torque as the pro1's and pro2's the whp wise wasn't that big of a difference..take into consideration what's done, what head, and whats the setup as awhole.. i think your best bet is which ever u can afford they are both a great cam..
Old Jan 9, 2008 | 06:11 PM
Mhollaek9's Avatar
Default Re: (D-Rob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Rob &raquo;</TD></TR><TR><TD CLASS="quote">
- Derek</TD></TR></TABLE>
I thought skunk 2 recommened 11+ compression for pro series cams. I'm have stage twos in my 85x89 build and there awesome but I sure would like to see how pro2s do. Good luck
Old Jan 9, 2008 | 06:44 PM
SpoonEk253's Avatar
***** it! im goin pro1's! ordering them tomorrow
Old Jan 9, 2008 | 06:50 PM
2fastGSR's Avatar
i think that is a good choice
Old Jan 9, 2008 | 07:30 PM
Mhollaek9's Avatar
dude nice choice. Where are you ordering it from if you dont mind me asking?
Old Jan 9, 2008 | 08:09 PM
SpoonEk253's Avatar
Default Re: B20vtec N/A, S2S2 or S2 pro1's?!?! (Mhollaek9)
pm'd!
Old Jan 10, 2008 | 09:40 AM
JCushing's Avatar
good choice, especially if you like power below 5500. the larger primaries of the pro series dominate down low....
Old Jan 10, 2008 | 11:25 AM
Mhollaek9's Avatar
im pretty sure 440cc would be good.... good luck on the build dude
Old Jan 10, 2008 | 11:49 AM
Fat Chick Magnet's Avatar
I only experienced pro 1's and pro 2's. I can't say much about stage 2's so I'm sticking with pro 1's/pro 2's.
Old Jan 10, 2008 | 05:27 PM
SpoonEk253's Avatar
Default Re: (Fat Chick Magnet)
yea im goin to keep you guys posted on the build and dyno numbers!
SunnyF23Vtec
Aug 22, 2015 12:52 PM
yakuza
Jun 4, 2008 02:32 PM
SpoonEk253
Jan 13, 2007 09:33 PM
sleepycivix
Nov 15, 2002 04:26 PM
