v-tec wire
Old Jan 8, 2008 | 08:51 AM
awdriver's Avatar
Default v-tec wire
so i was snooping around the engine bay a little in an attempt to locate the v-tec. i found it and when i did i noticed that there was no wire going to it. ie it is not hooked up to work.
so my question is: "where do i find one of the v-tect wire? and how much do they cost?"
thanks
ian
Old Jan 8, 2008 | 08:55 AM
20civic0000si's Avatar
Default Re: v-tec wire (awdriver)
Your vtec solenoid should actually have two wires, one for the solenoid and one for the pressure switch, but it would/should pull a CEL if it wasn't connected. What kind of car/motor combination are you talking about? R u sure it's a vtec ECU in your car?
Old Jan 8, 2008 | 09:05 AM
awdriver's Avatar
Default Re: v-tec wire (20civic0000si)
it is a 1994 dx with a jdm d15b. how do i know if it is a vtec ecu? i know nothing about these cars, i am a subaru guy. i am really ttrying to just fix this car to drive for a while then ultimately sell it. but i dont want to sell it with a vtecmotor and not have it work.
Old Jan 8, 2008 | 09:13 AM
pdotjones's Avatar
https://honda-tech.com/zerothread?id=810101 ecu's
https://honda-tech.com/zerothread?id=478377 ecu pinout
hope this helps
Old Jan 8, 2008 | 09:21 AM
awdriver's Avatar
Default Re: v-tec wire (pdotjones)
thanks. when i get home from work i will try to find out what ecu i have in it. i have a sneaking suspicion that it is not a vtec ecu.
thanks for the info.
Old Jan 8, 2008 | 09:23 AM
awdriver's Avatar
also does it cause a problem if it is a vtec motor and a non-vtec ecu?
Old Jan 8, 2008 | 09:24 AM
Archidictus's Avatar
Unceasing Measure
Default Re: (awdriver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by awdriver &raquo;</TD></TR><TR><TD CLASS="quote">also does it cause a problem if it is a vtec motor and a non-vtec ecu?</TD></TR></TABLE>
It causes the obvious problem of VTEC not working, but it won't do damage to the engine if that's what you're asking.
Old Jan 8, 2008 | 09:27 AM
awdriver's Avatar
Default Re: (Archidictus)
ok. thats good to know. like i said i dont want to sell this with a bad motor.
Old Jan 8, 2008 | 10:41 AM
awdriver's Avatar
Default Re:
if i do indeed have a vtec ecu, do i just need to get the wires for it and just plug and play? or ido i have to splice things together?
Old Jan 8, 2008 | 10:45 AM
wicked_b16eg's Avatar
Default Re: Re: (awdriver)
more or less "pin-splice" and play lol. You will have to splice into the pressure switch and pin the ecu. It's simple no worries lol, Just hit up you local radio shack
GL
1995civicEJ
Oct 1, 2006 11:15 AM
05 S2K Stoner
Oct 28, 2004 06:40 AM
mr. carpenter
May 5, 2004 09:47 PM
eazye5591
Dec 27, 2003 03:22 AM
