v-tec wire
v-tec wire
so i was snooping around the engine bay a little in an attempt to locate the v-tec. i found it and when i did i noticed that there was no wire going to it. ie it is not hooked up to work.
so my question is: "where do i find one of the v-tect wire? and how much do they cost?"
thanks
ian
thanks
ian
Re: v-tec wire (awdriver)
Your vtec solenoid should actually have two wires, one for the solenoid and one for the pressure switch, but it would/should pull a CEL if it wasn't connected. What kind of car/motor combination are you talking about? R u sure it's a vtec ECU in your car?
Re: v-tec wire (20civic0000si)
it is a 1994 dx with a jdm d15b. how do i know if it is a vtec ecu? i know nothing about these cars, i am a subaru guy. i am really ttrying to just fix this car to drive for a while then ultimately sell it. but i dont want to sell it with a vtecmotor and not have it work.
https://honda-tech.com/zerothread?id=810101 ecu's
https://honda-tech.com/zerothread?id=478377 ecu pinout
hope this helps
hope this helps
Re: v-tec wire (pdotjones)
thanks. when i get home from work i will try to find out what ecu i have in it. i have a sneaking suspicion that it is not a vtec ecu.
thanks for the info.
Unceasing Measure
Re: (awdriver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by awdriver »</TD></TR><TR><TD CLASS="quote">also does it cause a problem if it is a vtec motor and a non-vtec ecu?</TD></TR></TABLE>
It causes the obvious problem of VTEC not working, but it won't do damage to the engine if that's what you're asking.
Re: Re: (awdriver)
more or less "pin-splice" and play lol. You will have to splice into the pressure switch and pin the ecu. It's simple no worries lol, Just hit up you local radio shack
GL
GL
05 S2K Stoner
10-28-2004 06:40 AM
