Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
You're not going to believe this...
Old Jan 8, 2008 | 05:00 AM
Kent in KC's Avatar
Default You're not going to believe this...
The last time the dealer serviced my Element, they put the wrong air filter in! It is a full inch too short and also too large in diameter to snugly fit the mount. For umpteen thousand miles now I've been sucking unfiltered air down my engine. The throttle body looks like a dumpster. Gee, I wonder if that could be causing my TPS Code?
Old Jan 8, 2008 | 12:51 PM
crvpimpin's Avatar
Default Re: You're not going to believe this... (Kent in KC)
sounds like that dealer might be buying you a new engine
Old Jan 10, 2008 | 08:14 AM
aries331's Avatar
What's the dealer doing about it??
Old Jan 10, 2008 | 08:51 AM
95dxhatch's Avatar
which dealer did you go to? i'm from the area and worked at one of them several years ago
Old Jan 16, 2008 | 04:19 PM
cimo463's Avatar
There is no way they put the wrong filter in...there is only one style filter that goes in the housing that is used for the elements and crvs...they just might of not properly mounted it.
Cyber160
Jan 13, 2019 03:10 PM
john1233567
Oct 22, 2015 03:05 PM
bpfergu
Jan 17, 2012 10:09 AM
1hotcivicSi
Apr 7, 2004 01:22 PM
Lazydsm
Apr 29, 2003 07:28 AM
